network fcp topology show
FCP topology interconnect elements per adapter
Display FCP topology interconnect elements per adapter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to select the interconnect elements for adapters that are located on the node that you specify.
[-adapter <text>]
- Adapter-
Use this parameter to select the interconnect elements for the specified adapter.
[-domain-id <integer>]
- Domain Id-
Use this parameter to select the interconnect elements with the specified domain identifier.
[-port-wwpn <text>]
- Port WWPN-
Use this parameter to select the interconnect elements with the specified port world wide name.
[-switch-name <text>]
- Switch Name-
Use this parameter to select the interconnect elements with the specified switch.
[-switch-vendor <text>]
- Switch Vendor-
Use this parameter to select the interconnect elements with the specified vendor.
[-switch-release <text>]
- Switch Release-
Use this parameter to select the interconnect elements with the specified release.
[-switch-wwpn <text>]
- Switch WWPN-
Use this parameter to select the interconnect elements with the specified world wide port name.
[-switch-wwn <text>]
- Switch WWN-
Use this parameter to select the interconnect elements with the specified world wide name.
[-port-count <integer>]
- Port Count-
Use this parameter to select the interconnect elements with the specified port count.
[-port-slot <text>]
- Port Slot-
Use this parameter to select the interconnect elements with the specified port slot.
[-port-state {Unknown|Online|Offline|Testing|Fault}]
- Port State-
Use this parameter to select the interconnect elements with the specified port state.
[-port-type {None|N-Port|NL-Port|FNL-Port|NX-Port|F-Port|FL-Port|E-Port|B-Port|TNP-Port|TF-Port|NV-Port|FV-Port|SD-Port|TE-Port|TL-Port}]
- Port Type-
Use this parameter to select the interconnect elements with the specified port type.
[-port-attached-wwpn <text>]
- Attached Port WWPN-
Use this parameter to select the interconnect elements with the specified attached wwpn.
[-port-attached-id <text>]
- Attached Port Id-
Use this parameter to select the interconnect elements with the specified attached id.
[-port-attached-visible <text>]
- Visible-
Use this parameter to select the interconnect elements with the specified visiblity flag on attached port structure.
cluster1::> network fcp topology show Switch connected to the adapter 0c Switch Name: ssan-fc0e-d58 Switch Vendor: Cisco Systems, Inc. Switch Release: 5.2(1)N1(9) Switch Domain: 4 Switch WWN: 20:05:00:05:9b:26:f4:c1 Port Count: 20 Port Port WWN State Type Attached WWPN Port Id ------- ----------------------- --------- --------- ----------------------- ------------ vfc9 20:08:00:05:9b:26:f4:ff Offline None - - vfc10 20:15:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:82:8d:92:4c:ff 0x0407c0 * vfc11 20:16:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:81:8d:e2:4e:ec 0x040800 * Switch connected to the adapter 0c Switch Name: ssan-fc0e-d58 Switch Vendor: Cisco Systems, Inc. Switch Release: 5.2(1)N1(9) Switch Domain: 4 Switch WWN: 20:05:00:05:9b:26:f4:c1 Port Count: 20 Port Port WWN State Type Attached WWPN Port Id ------- ----------------------- --------- --------- ----------------------- ------------ vfc20 20:13:00:05:9b:26:f4:ff Offline None - - vfc21 20:14:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:81:8d:92:4c:ff 0x0407a0 * 5 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
