lun move show
Display a list LUNs currently being moved
The lun move show
command shows information about LUNs currently being moved in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Selects LUN move operations that match this parameter value.
[-destination-path <text>]
- Destination Path-
[-source-path <path>]
- Source Path-
[-is-promoted-late {true|false}]
- Is Destination Promoted Late-
[-max-throughput {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Transfer Rate (per sec)-
[-job-status {Preparing|Allocation-Map|Data|Destroying|Paused-Admin|Paused-Error|Complete|Destroyed}]
- LUN Move Status-
Selects LUN move operations that match this parameter value. The possible values are:
Preparing
- the LUN move job is in Preparing status. -
Allocation-Map
- the LUN move job is in Allocating status. -
Data
- the LUN move job is in Moving Data status. -
Destroying
- the LUN move job is in Destroying status. -
Paused-Admin
- the LUN move job is in Paused By Admin status. -
Paused-Error
- the LUN move job is in Paused By Error status. -
Complete
- the LUN move job is in Complete status. -
Destroyed
- the LUN move job is in Destroyed status.
[-progress-percent <percent>]
- LUN Move Progress (%)-
[-elapsed-time <time_interval>]
- Elapsed Time-
[-cutover-time <time_interval>]
- Cutover Time-
[-is-snapshot-fenced {true|false}]
- Is Snapshot Fenced-
[-is-destination-ready {true|false}]
- Is Destination Ready-
[-last-failure-reason <text>]
- Last Failure Reason-
cluster1::> lun move show Vserver Destination Path Status Progress --------- ------------------------------- --------------- -------- vs1 /vol/vol2/lun1 Data 35% vs1 /vol/vol2/lun2 Complete 100% 2 entries were displayed.
The example above displays information about all the LUN move operations in the cluster.
cluster1::> lun move show -vserver vs1 -destination-path /vol/vol2/lun1 -instance Destination Vserver Name: vs1 Destination Path: /vol/vol2/lun1 Source Path: /vol/vol1/lun1 Is Destination Promoted Early: false Maximum Transfer Rate (per sec): 0B LUN Move Status: Data LUN Move Progress (%): 35% Elapsed Time: 145s Cutover Time (secs): 0s Is Snapshot Fenced: true Is Destination Ready: true Last Failure Reason: -
The example above displays all information about the LUN being moved to /vol/vol2/lun1
in Vserver vs1
