vserver add-aggregates
Add aggregates to the Vserver
The vserver add-aggregates
command adds aggregates to the Vserver.
-vserver <vserver>
- Vserver-
Specifies the Vserver for which aggregates have to be added.
-aggregates <aggregate name>,…
- List of Aggregates to Be Added-
Specifies the list of aggregates to add to the Vserver. The root aggregates should not be specified in this list because though the command will return success, volumes cannot be created on root aggregates. In a MetroCluster configuration, this command does not honor the remote cluster’s aggregates.
The following example illustrates how to add aggregates aggr1
and aggr2
to a Vserver named vs.example.com
cluster1::> vserver add-aggregates -vserver vs.example.com -aggregates aggr1,aggr2
