system services manager install show
Display a list of installed services
The system services manager install show command displays information about installed services.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-service <text>] - Service
Selects information about installed services that have the name you specify.
[-version <service version>] - Version
Selects information about installed services that have the version number you specify.
[-constituent <text>] - Constituent
Selects information about installed services that have the constituent process you specify.
[-nodes {<nodename>|local}] - Nodes
Selects information about services that are installed on the nodes you specify.
[-description <text>] - Description
Selects information about installed services that match the description you specify.
The following example shows typical output from a two-node cluster.
cluster1::> system services manager install show
Service           Version Constituent Nodes
diagnosis
                  1.0     schmd       node1, node2
                  1.0     shmd        node1, node2
2 entries were displayed.
