volume object-store tiering show
PDF of this doc site
Creating your file...
Display Tiering Status of FabricPool Volumes
The volume object-store tiering show
command displays information about the tiering scanner status of FabricPool aggregate volumes. The tiering scanner will, depending on the combination of the tiering-policy and cloud-retrieval-policy settings, both retrieve from and tier to the capacity tier. This show command can be used to display the status of the scanner, whether it has aborted, what errors it has encountered and when it will be scheduled to run again.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver (privilege: advanced)-
vserver name
[-volume <volume name>]
- Volume (privilege: advanced)-
volume name
[-node <nodename>]
- Node Name (privilege: advanced)-
node name
[-vol-dsid <integer>]
- Volume DSID (privilege: advanced)-
volume dsid
[-aggregate <aggregate name>]
- Aggregate Name (privilege: advanced)-
aggregate name
[-scanner-state {ready|active|waiting}]
- State (privilege: advanced)-
The state of the scanner. The values active, ready and waiting may appear in this field. Active means the scanner is currently running, waiting means the scanner is waiting to be scheduled, and ready means the scanner is ready to run. Once a scanner is ready to run, it must be scheduled by the system's scan scheduler, the amount of time it takes for it to become active is variable and depends on how busy the system is..
[-scanner-last-status {aborted-nospace-promote|aborted-fabricpool|aborted-nospace-defrag|abortted-nospace|aborted-exception|aborted-policy|aborted|completed|prev-not-run|aborted-defrag-throttled}]
- Previous Run Status (privilege: advanced)-
The status of the tiering scanner the last time it ran. This field will indicate if the scanner has aborted or completed.
[-scanner-abort-exception <integer>]
- Aborted Exception Status (privilege: advanced)-
If the scanner last status indicates the scanner aborted with an exception then this field is set to the exception error code that caused the abort.
[-time-last-scan <Date>]
- Time Scanner Last Finished (privilege: advanced)-
This field displays the date and time the last scanner status field was set.
[-scan-percent <percent>]
- Scanner Percent Complete (privilege: advanced)-
This field displays the completion percentage of scans in the active state.
[-time-next-scan <Date>]
- Time Waiting Scan will be scheduled (privilege: advanced)-
This field displays the date and time scans in the waiting state will enter the ready state.
[-tiering-policy {snapshot-only|auto|none|all}]
- Tiering Policy (privilege: advanced)-
The tiering policy. This field displays the currnet tiering-policy in effect on the volume.
[-promotion-space-needed {<integer>[KB|MB|GB|TB|PB]}]
- Estimated Space Needed for Promotion (privilege: advanced)-
If the scanner aborted due to no space for promote, then this field is set to the estimated minimum space required for promotion to take effect.
[-scan-start-time <Date>]
- Time Scan Started (privilege: advanced)-
This field displays the date and time the scan, if in active state, started.
[-cloud-retrieval-policy {default|on-read|never|promote}]
- Cloud Retrieval Policy (privilege: advanced)-
The cloud retrieval policy. This field displays the current cloud-retrieval-policy in effect on the volume.
[-scan-elapsed-time <[<integer>h][<integer>m][<integer>s]>]
- Elapsed Time Scanner Ran (privilege: advanced)-
This field displays the time it took for the last scan to run to complete or abort.
cluster1::> volume object-store tiering show Policy Vserver Volume Aggregate State %Complete Tiering CloudRetrieve LastStatus ------- ------ --------- -------- --------- --------- ------------- ---------- vs1 vol aggr1 waiting - snapshot-only default completed
Shows the tiering status for all FabricPool volumes.
