snapmirror failover show
Display failover status
The `snapmirror failover show ` command displays the failover status of SnapMirror relationships with 'automated-failover' policy-type.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-start-time <MM/DD/YYYY HH:MM:SS>]- Start Time-
Start operation time of the failover.
[-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[cgname]>}]- Source Path-
Specifies the source endpoint of the SnapMirror relationship.
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[cgname]>}]- Destination Path-
Specifies the destination endpoint of the SnapMirror relationship.
[-status {started|failed|completed|completed_with_warnings}]- Failover Status-
Ths status of snapmirror failover.
[-error-reason <text>]- Error Reason-
The reason for failure occured during snapmirror failover.
[-end-time <MM/DD/YYYY HH:MM:SS>]- End Time-
End operation time of the failover.
[-primary-data-cluster <text>]- Primary Data Cluster-
Primary data cluster.
[-last-progress-update <text>]- Last Progress Update-
Last progress update.
[-type {planned|unplanned|incapable}]- Failover Type-
Whether the SnapMirror failover was planned or unplanned.
[-error-reason-codes <integer>,…]- Error Reason codes-
The reason codes for failure occured during snapmirror failover.
