vserver cifs cache name-to-sid delete
Delete an entry
The vserver cifs cache name-to-sid delete command removes the Windows user cache entries cached by the Windows name. If cache propagation is enabled, the corresponding sid-to-name cache entry will also be removed.
-vserver <vserver name> - Vserver (privilege: advanced)
Use this parameter to specify the Vserver for which the name-to-sid cache entry needs to be deleted.
-win-name <text> - Windows Name (privilege: advanced)
Use this parameter to specify the Windows name for which the cached entry needs to be deleted.
The following example shows how to delete the name-to-sid cache entry for Vserver vs0 with Windows name user1:
cluster1::> vserver cifs cache name-to-sid delete -vserver vs0 -win-name user1
