network bgp peer-group create
Create a new BGP peer group
The network bgp peer-group create command is used to create a border gateway protocol (BGP) peer group. A BGP peer group will advertise VIP routes for the list of vservers in the peer group's vserver-list using the BGP LIF of the peer group. A BGP peer group will advertise VIP routes to a peer router using the border gateway protocol. The address of the peer router is identfied by the peer-address value.
-ipspace <IPspace>- IPspace Name-
This parameter specifies the IPspace of the peer group being created.
-peer-group <text>- Peer Group Name-
This parameter specifies the name of the peer group being created.
-bgp-lif <lif-name>- BGP LIF-
This parameter specifies the BGP interface (BGP LIF) of the peer group being created.
-peer-address <IP Address>- Peer Router Address-
This parameter specifies the IP address of the peer router for the peer group being created.
[-peer-asn <integer>]- Peer Router Autonomous number-
This parameter specifies the peer router autonomous system number (ASN) in the peer group being created. The default value is the value of the local node's ASN.
-route-preference <integer>- Route Preference-
This parameter specifies the preference field in BGP update messages for VIP routes. If a router receives multiple VIP route announcements for the same VIP LIF from different BGP LIFs, it will install the one that has the highest preference value. The default route preference value is 100.
[-asn-prepend-type <ASN Prepend type>]- ASN prepend type (privilege: advanced)-
This parameter specifies the ASN that will be prepended in the BGP attributes. The possible values are
local-asnandpeer-asn. The default behaviour is not to prepend any ASN. [-asn-prepend-count <integer>]- ASN prepend count (privilege: advanced)-
This parameter specifies the number of times ASN, as specified in
asn-prepend-typewill be prepended in the BGP path attributes. The default behaviour is not to prepend any ASN. [-community <BGP community>,…]- BGP Community (privilege: advanced)-
This parameter specifies the communities that will be included in the BGP path attributes. The default behaviour is not to include any community in BGP path attributes.
cluster1::> network bgp peer-group create -peer-group group1 -ipspace Default -bgp-lif bgp_lif -peer-address 10.0.1.112
