event snmphistory delete
(DEPRECATED)-Delete an SNMP trap history record
This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event notification history" command set. |
The event snmphistory delete command deletes an SNMP trap-history record. To delete a record, you will need to know which node generated the event, and you will need to know the sequence number of that event in the trap-history.
Use the event snmphistory show command to display a list of trap-history records and their sequence numbers.
-node {<nodename>|local}- Node-
Use this parameter to specify the name of the node that contains the snmp history record to delete.
-seqnum <Sequence Number>- Sequence Number-
Use this parameter to specify the sequence number of the SNMP trap-history record to delete.
The following example deletes all SNMP trap-history records on node1:
cluster1::> event snmphistory delete -node node1 -seqnum *
