Docs
All NetApp
BlueXP
Support
Knowledge Base
Training
All docs
ONTAP
ONTAP 9.8 commands
Version
9.8
9.8
9.13.1
9.12.1
9.11.1
9.10.1
9.9.1
9.7
9.6
9.5
9.3
ONTAP 9.8 commands
exit
history
man
redo
rows
set
top
up
application commands
application provisioning commands
application provisioning config modify
application provisioning config show
autobalance commands
autobalance aggregate commands
autobalance aggregate show-aggregate-state
autobalance aggregate show-unbalanced-volume-state
autobalance aggregate config modify
autobalance aggregate config show
cluster commands
cluster add-node-status
cluster add-node
cluster create
cluster join
cluster modify
cluster ping-cluster
cluster remove-node
cluster setup
cluster show
cluster contact-info commands
cluster contact-info modify
cluster contact-info show
cluster controller-replacement commands
cluster controller-replacement network displaced-interface delete
cluster controller-replacement network displaced-interface restore-home-node
cluster controller-replacement network displaced-interface show
cluster controller-replacement network displaced-vlans delete
cluster controller-replacement network displaced-vlans restore
cluster controller-replacement network displaced-vlans show
cluster date commands
cluster date modify
cluster date show
cluster date zoneinfo load-from-uri
cluster date zoneinfo show
cluster ha commands
cluster ha modify
cluster ha show
cluster identity commands
cluster identity modify
cluster identity show
cluster image commands
cluster image cancel-update
cluster image pause-update
cluster image resume-update
cluster image show-update-history
cluster image show-update-log-detail
cluster image show-update-progress
cluster image show
cluster image update
cluster image validate
cluster image package delete
cluster image package get
cluster image package show-repository
cluster kernel-service commands
cluster kernel-service show
cluster kernel-service config modify
cluster kernel-service config show
cluster log-forwarding commands
cluster log-forwarding create
cluster log-forwarding delete
cluster log-forwarding modify
cluster log-forwarding show
cluster peer commands
cluster peer create
cluster peer delete
cluster peer modify-local-name
cluster peer modify
cluster peer ping
cluster peer show
cluster peer connection show
cluster peer health show
cluster peer offer cancel
cluster peer offer modify
cluster peer offer show
cluster peer policy modify
cluster peer policy show
cluster quorum-service commands
cluster quorum-service options modify
cluster quorum-service options show
cluster ring commands
cluster ring show
cluster statistics commands
cluster statistics show
cluster time-service commands
cluster time-service ntp key create
cluster time-service ntp key delete
cluster time-service ntp key modify
cluster time-service ntp key show
cluster time-service ntp security modify
cluster time-service ntp security show
cluster time-service ntp server create
cluster time-service ntp server delete
cluster time-service ntp server modify
cluster time-service ntp server reset
cluster time-service ntp server show
cluster time-service ntp status show
event commands
event catalog commands
event catalog show
event config commands
event config force-sync
event config modify
event config set-proxy-password
event config show
event destination commands
event destination create
event destination delete
event destination modify
event destination show
event filter commands
event filter copy
event filter create
event filter delete
event filter rename
event filter show
event filter test
event filter rule add
event filter rule delete
event filter rule reorder
event log commands
event log show
event mailhistory commands
event mailhistory delete
event mailhistory show
event notification commands
event notification create
event notification delete
event notification modify
event notification show
event notification destination create
event notification destination delete
event notification destination modify
event notification destination show
event notification history show
event route commands
event route add-destinations
event route modify
event route remove-destinations
event route show
event snmphistory commands
event snmphistory delete
event snmphistory show
event status commands
event status show
job commands
job delete
job pause
job resume
job show-bynode
job show-cluster
job show-completed
job show
job stop
job unclaim
job watch-progress
job history commands
job history show
job initstate commands
job initstate show
job private commands
job private delete
job private pause
job private resume
job private show-completed
job private show
job private stop
job private watch-progress
job schedule commands
job schedule delete
job schedule show-jobs
job schedule show
job schedule cron create
job schedule cron delete
job schedule cron modify
job schedule cron show
job schedule interval create
job schedule interval delete
job schedule interval modify
job schedule interval show
lun commands
lun create
lun delete
lun maxsize
lun modify
lun move-in-volume
lun resize
lun show
lun bind commands
lun bind create
lun bind destroy
lun bind show
lun copy commands
lun copy cancel
lun copy modify
lun copy pause
lun copy resume
lun copy show
lun copy start
lun igroup commands
lun igroup add
lun igroup bind
lun igroup create
lun igroup delete
lun igroup disable-aix-support
lun igroup modify
lun igroup remove
lun igroup rename
lun igroup show
lun igroup unbind
lun import commands
lun import create
lun import delete
lun import pause
lun import prepare-to-downgrade
lun import resume
lun import show
lun import start
lun import stop
lun import throttle
lun import verify start
lun import verify stop
lun mapping commands
lun mapping add-reporting-nodes
lun mapping create
lun mapping delete
lun mapping remove-reporting-nodes
lun mapping show-initiator
lun mapping show
lun move commands
lun move cancel
lun move modify
lun move pause
lun move resume
lun move show
lun move start
lun persistent-reservation commands
lun persistent-reservation clear
lun persistent-reservation show
lun portset commands
lun portset add
lun portset create
lun portset delete
lun portset remove
lun portset show
lun transition commands
lun transition show
lun transition start
lun transition 7-mode delete
lun transition 7-mode show
metrocluster commands
metrocluster configure
metrocluster heal
metrocluster modify
metrocluster remove-dr-group
metrocluster show
metrocluster switchback
metrocluster switchover
metrocluster check commands
metrocluster check disable-periodic-check
metrocluster check enable-periodic-check
metrocluster check run
metrocluster check show
metrocluster check aggregate show
metrocluster check cluster show
metrocluster check config-replication show-aggregate-eligibility
metrocluster check config-replication show-capture-status
metrocluster check connection show
metrocluster check lif repair-placement
metrocluster check lif show
metrocluster check node show
metrocluster check volume show
metrocluster config-replication commands
metrocluster config-replication cluster-storage-configuration modify
metrocluster config-replication cluster-storage-configuration show
metrocluster config-replication resync-status show
metrocluster configuration-settings commands
metrocluster configuration-settings show-status
metrocluster configuration-settings calibration measure
metrocluster configuration-settings calibration show
metrocluster configuration-settings connection check
metrocluster configuration-settings connection connect
metrocluster configuration-settings connection disconnect
metrocluster configuration-settings connection show
metrocluster configuration-settings dr-group create
metrocluster configuration-settings dr-group delete
metrocluster configuration-settings dr-group show
metrocluster configuration-settings interface create
metrocluster configuration-settings interface delete
metrocluster configuration-settings interface show
metrocluster configuration-settings mediator add
metrocluster configuration-settings mediator remove
metrocluster configuration-settings mediator show
metrocluster interconnect commands
metrocluster interconnect adapter modify
metrocluster interconnect adapter show
metrocluster interconnect mirror show
metrocluster interconnect mirror multipath show
metrocluster node commands
metrocluster node show
metrocluster operation commands
metrocluster operation show
metrocluster operation history show
metrocluster transition commands
metrocluster transition disable
metrocluster transition enable
metrocluster transition show-mode
metrocluster vserver commands
metrocluster vserver recover-from-partial-switchback
metrocluster vserver recover-from-partial-switchover
metrocluster vserver resync
metrocluster vserver show
network commands
network ping
network ping6
network test-path
network traceroute
network traceroute6
network arp commands
network arp create
network arp delete
network arp show
network arp active-entry delete
network arp active-entry show
network bgp commands
network bgp config create
network bgp config delete
network bgp config modify
network bgp config show
network bgp defaults modify
network bgp defaults show
network bgp peer-group create
network bgp peer-group delete
network bgp peer-group modify
network bgp peer-group rename
network bgp peer-group show
network bgp vserver-status show
network cloud commands
network cloud routing-table create
network cloud routing-table delete
network cloud routing-table show
network connections commands
network connections active show-clients
network connections active show-lifs
network connections active show-protocols
network connections active show-services
network connections listening show
network device-discovery commands
network device-discovery show
network fcp commands
network fcp adapter modify
network fcp adapter show
network fcp topology show
network fcp zone show
network interface commands
network interface create
network interface delete
network interface migrate-all
network interface modify
network interface rename
network interface revert
network interface show
network interface start-cluster-check
network interface capacity show
network interface capacity details show
network interface check failover show
network interface dns-lb-stats show
network interface failover-groups add-targets
network interface failover-groups create
network interface failover-groups delete
network interface failover-groups modify
network interface failover-groups remove-targets
network interface failover-groups rename
network interface failover-groups show
network interface lif-weights show
network interface service show
network interface service-policy add-service
network interface service-policy clone
network interface service-policy create
network interface service-policy delete
network interface service-policy modify-service
network interface service-policy remove-service
network interface service-policy rename
network interface service-policy restore-defaults
network interface service-policy show
network ipspace commands
network ipspace create
network ipspace delete
network ipspace rename
network ipspace show
network ndp commands
network ndp default-router delete-all
network ndp default-router show
network ndp neighbor create
network ndp neighbor delete
network ndp neighbor show
network ndp neighbor active-entry delete
network ndp neighbor active-entry show
network ndp prefix delete-all
network ndp prefix show
network options commands
network options cluster-health-notifications modify
network options cluster-health-notifications show
network options detect-switchless-cluster modify
network options detect-switchless-cluster show
network options ipv6 modify
network options ipv6 show
network options load-balancing modify
network options load-balancing show
network options multipath-routing modify
network options multipath-routing show
network options port-health-monitor disable-monitors
network options port-health-monitor enable-monitors
network options port-health-monitor modify
network options port-health-monitor show
network options send-soa modify
network options send-soa show
network options switchless-cluster modify
network options switchless-cluster show
network port commands
network port delete
network port modify
network port show-address-filter-info
network port show
network port broadcast-domain add-ports
network port broadcast-domain create
network port broadcast-domain delete
network port broadcast-domain merge
network port broadcast-domain modify
network port broadcast-domain move
network port broadcast-domain remove-ports
network port broadcast-domain rename
network port broadcast-domain show
network port broadcast-domain split
network port ifgrp add-port
network port ifgrp create
network port ifgrp delete
network port ifgrp remove-port
network port ifgrp show
network port reachability repair
network port reachability scan
network port reachability show
network port vip create
network port vip delete
network port vip show
network port vlan create
network port vlan delete
network port vlan show
network qos-marking commands
network qos-marking modify
network qos-marking show
network route commands
network route create
network route delete
network route show-lifs
network route show
network route active-entry show
network subnet commands
network subnet add-ranges
network subnet create
network subnet delete
network subnet modify
network subnet remove-ranges
network subnet rename
network subnet show
network tcpdump commands
network tcpdump show
network tcpdump start
network tcpdump stop
network tcpdump trace delete
network tcpdump trace show
network test-link commands
network test-link run-test
network test-link show
network test-link start-server
network test-link stop-server
network tuning commands
network tuning icmp modify
network tuning icmp show
network tuning icmp6 modify
network tuning icmp6 show
network tuning tcp modify
network tuning tcp show
protection-type commands
protection-type show
qos commands
qos adaptive-policy-group commands
qos adaptive-policy-group create
qos adaptive-policy-group delete
qos adaptive-policy-group modify
qos adaptive-policy-group rename
qos adaptive-policy-group show
qos policy-group commands
qos policy-group create
qos policy-group delete
qos policy-group modify
qos policy-group rename
qos policy-group show
qos settings commands
qos settings throughput-floors-v2
qos settings cache modify
qos settings cache show
qos statistics commands
qos statistics characteristics show
qos statistics latency show
qos statistics performance show
qos statistics resource cpu show
qos statistics resource disk show
qos statistics volume characteristics show
qos statistics volume latency show
qos statistics volume performance show
qos statistics volume resource cpu show
qos statistics volume resource disk show
qos statistics workload characteristics show
qos statistics workload latency show
qos statistics workload performance show
qos statistics workload resource cpu show
qos statistics workload resource disk show
qos workload commands
qos workload delete
qos workload show
san commands
san config commands
san config show
security commands
security snmpusers
security audit commands
security audit modify
security audit show
security audit log show
security certificate commands
security certificate create
security certificate delete
security certificate generate-csr
security certificate install
security certificate print
security certificate rename
security certificate show-generated
security certificate show-truststore
security certificate show-user-installed
security certificate sign
security certificate ca-issued revoke
security certificate ca-issued show
security certificate config modify
security certificate config show
security certificate truststore check
security certificate truststore clear
security certificate truststore load
security config commands
security config modify
security config show
security config ocsp disable
security config ocsp enable
security config ocsp show
security config status show
security ipsec commands
security ipsec show-ikesa
security ipsec show-ipsecsa
security ipsec config modify
security ipsec config show
security ipsec policy create
security ipsec policy delete
security ipsec policy modify
security ipsec policy show
security key-manager commands
security key-manager add
security key-manager create-key
security key-manager delete-key-database
security key-manager delete-kmip-config
security key-manager prepare-to-downgrade
security key-manager query
security key-manager restore
security key-manager setup
security key-manager show-key-store
security key-manager update-passphrase
security key-manager backup show
security key-manager config modify
security key-manager config show
security key-manager external add-servers
security key-manager external disable
security key-manager external enable
security key-manager external modify-server
security key-manager external remove-servers
security key-manager external restore
security key-manager external show-status
security key-manager external azure disable
security key-manager external azure enable
security key-manager external azure rekey-external
security key-manager external azure rekey-internal
security key-manager external azure restore
security key-manager external azure show
security key-manager external azure update-client-secret
security key-manager external boot-interfaces modify
security key-manager external boot-interfaces show
security key-manager key create
security key-manager key delete
security key-manager key migrate
security key-manager key query
security key-manager key show
security key-manager onboard disable
security key-manager onboard enable
security key-manager onboard show-backup
security key-manager onboard sync
security key-manager onboard update-passphrase
security key-manager onboard verify-backup
security login commands
security login create
security login delete
security login expire-password
security login lock
security login modify
security login password-prepare-to-downgrade
security login show
security login unlock
security login whoami
security login banner modify
security login banner show
security login domain-tunnel create
security login domain-tunnel delete
security login domain-tunnel modify
security login domain-tunnel show
security login motd modify
security login motd show
security login publickey create
security login publickey delete
security login publickey load-from-uri
security login publickey modify
security login publickey show
security login rest-role create
security login rest-role delete
security login rest-role modify
security login rest-role show
security login role create
security login role delete
security login role modify
security login role prepare-to-downgrade
security login role show-ontapi
security login role config modify
security login role config reset
security login role config show
security protocol commands
security protocol modify
security protocol show
security protocol ssh modify
security protocol ssh show
security saml-sp commands
security saml-sp create
security saml-sp delete
security saml-sp modify
security saml-sp repair
security saml-sp show
security saml-sp status show
security session commands
security session kill-cli
security session show
security session limit create
security session limit delete
security session limit modify
security session limit show
security session limit application create
security session limit application delete
security session limit application modify
security session limit application show
security session limit location create
security session limit location delete
security session limit location modify
security session limit location show
security session limit request create
security session limit request delete
security session limit request modify
security session limit request show
security session limit user create
security session limit user delete
security session limit user modify
security session limit user show
security session limit vserver create
security session limit vserver delete
security session limit vserver modify
security session limit vserver show
security session request-statistics show-by-application
security session request-statistics show-by-location
security session request-statistics show-by-request
security session request-statistics show-by-user
security session request-statistics show-by-vserver
security ssh commands
security ssh add
security ssh modify
security ssh prepare-to-downgrade
security ssh remove
security ssh show
security ssl commands
security ssl modify
security ssl show
security tpm commands
security tpm show
snaplock commands
snaplock compliance-clock commands
snaplock compliance-clock initialize
snaplock compliance-clock show
snaplock compliance-clock ntp modify
snaplock compliance-clock ntp show
snaplock event-retention commands
snaplock event-retention abort
snaplock event-retention apply
snaplock event-retention show-vservers
snaplock event-retention policy create
snaplock event-retention policy delete
snaplock event-retention policy modify
snaplock event-retention policy show
snaplock legal-hold commands
snaplock legal-hold abort
snaplock legal-hold begin
snaplock legal-hold dump-files
snaplock legal-hold dump-litigations
snaplock legal-hold end
snaplock legal-hold show
snaplock log commands
snaplock log create
snaplock log delete
snaplock log modify
snaplock log show
snaplock log file archive
snaplock log file show
snapmirror commands
snapmirror abort
snapmirror break
snapmirror create
snapmirror delete
snapmirror initialize-ls-set
snapmirror list-destinations
snapmirror modify
snapmirror promote
snapmirror protect
snapmirror quiesce
snapmirror release
snapmirror restore
snapmirror resume
snapmirror resync
snapmirror set-options
snapmirror show-history
snapmirror show
snapmirror update-ls-set
snapmirror update
snapmirror config-replication commands
snapmirror config-replication cluster-storage-configuration modify
snapmirror config-replication cluster-storage-configuration show
snapmirror config-replication status show-aggregate-eligibility
snapmirror config-replication status show-communication
snapmirror failover commands
snapmirror failover show
snapmirror failover start
snapmirror mediator commands
snapmirror mediator add
snapmirror mediator remove
snapmirror mediator show
snapmirror object-store commands
snapmirror object-store profiler abort
snapmirror object-store profiler show
snapmirror object-store profiler start
snapmirror policy commands
snapmirror policy add-rule
snapmirror policy create
snapmirror policy delete
snapmirror policy modify-rule
snapmirror policy remove-rule
snapmirror policy show
snapmirror snapshot-owner commands
snapmirror snapshot-owner create
snapmirror snapshot-owner delete
snapmirror snapshot-owner show
statistics commands
statistics show-periodic
statistics show
statistics start
statistics stop
statistics aggregate commands
statistics aggregate show
statistics cache commands
statistics cache flash-pool show
statistics catalog commands
statistics catalog counter show
statistics catalog instance show
statistics catalog object show
statistics disk commands
statistics disk show
statistics lif commands
statistics lif show
statistics lun commands
statistics lun show
statistics namespace commands
statistics namespace show
statistics nfs commands
statistics nfs show-mount
statistics nfs show-nlm
statistics nfs show-statusmon
statistics nfs show-v3
statistics nfs show-v4
statistics nfs show-v41
statistics node commands
statistics node show
statistics oncrpc commands
statistics oncrpc show-rpc-calls
statistics port commands
statistics port fcp show
statistics preset commands
statistics preset delete
statistics preset modify
statistics preset show
statistics preset detail show
statistics qtree commands
statistics qtree show
statistics samples commands
statistics samples delete
statistics samples show
statistics settings commands
statistics settings modify
statistics settings show
statistics system commands
statistics system show
statistics top commands
statistics top client show
statistics top file show
statistics volume commands
statistics volume show
statistics vserver commands
statistics vserver show
statistics workload commands
statistics workload show
statistics-v1 commands
statistics-v1 nfs commands
statistics-v1 nfs show-mount
statistics-v1 nfs show-nlm
statistics-v1 nfs show-statusmon
statistics-v1 nfs show-v3
statistics-v1 nfs show-v4
statistics-v1 nfs show-v41
statistics-v1 protocol-request-size commands
statistics-v1 protocol-request-size show
storage-service commands
storage-service show
storage commands
storage aggregate commands
storage aggregate add-disks
storage aggregate auto-provision
storage aggregate create
storage aggregate delete
storage aggregate mirror
storage aggregate modify
storage aggregate offline
storage aggregate online
storage aggregate remove-stale-record
storage aggregate rename
storage aggregate restrict
storage aggregate scrub
storage aggregate show-auto-provision-progress
storage aggregate show-cumulated-efficiency
storage aggregate show-efficiency
storage aggregate show-resync-status
storage aggregate show-scrub-status
storage aggregate show-space
storage aggregate show-spare-disks
storage aggregate show-status
storage aggregate verify
storage aggregate efficiency show
storage aggregate efficiency stat
storage aggregate efficiency cross-volume-dedupe revert-to
storage aggregate efficiency cross-volume-dedupe show
storage aggregate efficiency cross-volume-dedupe start
storage aggregate efficiency cross-volume-dedupe stop
storage aggregate encryption show-key-id
storage aggregate inode-upgrade resume
storage aggregate inode-upgrade show
storage aggregate object-store attach
storage aggregate object-store mirror
storage aggregate object-store modify
storage aggregate object-store show-freeing-status
storage aggregate object-store show-resync-status
storage aggregate object-store show-space
storage aggregate object-store unmirror
storage aggregate object-store config create
storage aggregate object-store config delete
storage aggregate object-store config modify
storage aggregate object-store config rename
storage aggregate object-store config show
storage aggregate object-store profiler abort
storage aggregate object-store profiler show
storage aggregate object-store profiler start
storage aggregate plex delete
storage aggregate plex offline
storage aggregate plex online
storage aggregate plex show
storage aggregate reallocation quiesce
storage aggregate reallocation restart
storage aggregate reallocation schedule
storage aggregate reallocation show
storage aggregate reallocation start
storage aggregate reallocation stop
storage aggregate relocation show
storage aggregate relocation start
storage aggregate resynchronization modify
storage aggregate resynchronization show
storage aggregate resynchronization options modify
storage aggregate resynchronization options show
storage array commands
storage array modify
storage array remove
storage array rename
storage array show
storage array config show
storage array disk paths show
storage array port modify
storage array port remove
storage array port show
storage automated-working-set-analyzer commands
storage automated-working-set-analyzer show
storage automated-working-set-analyzer start
storage automated-working-set-analyzer stop
storage automated-working-set-analyzer volume show
storage disk commands
storage disk assign
storage disk fail
storage disk reassign
storage disk refresh-ownership
storage disk remove-reservation
storage disk remove
storage disk removeowner
storage disk replace
storage disk set-foreign-lun
storage disk set-led
storage disk show
storage disk unfail
storage disk updatefirmware
storage disk zerospares
storage disk error show
storage disk firmware revert
storage disk firmware show-update-status
storage disk firmware update
storage disk option modify
storage disk option show
storage dqp commands
storage dqp show
storage encryption commands
storage encryption disk destroy
storage encryption disk modify
storage encryption disk revert-to-original-state
storage encryption disk sanitize
storage encryption disk show-status
storage errors commands
storage errors show
storage failover commands
storage failover giveback
storage failover modify
storage failover show-giveback
storage failover show-takeover
storage failover takeover
storage failover hwassist show
storage failover hwassist test
storage failover hwassist stats clear
storage failover hwassist stats show
storage failover internal-options show
storage failover mailbox-disk show
storage failover progress-table show
storage firmware commands
storage firmware download
storage firmware acp delete
storage firmware acp rename
storage firmware acp show
storage firmware disk delete
storage firmware disk rename
storage firmware disk show
storage firmware shelf delete
storage firmware shelf rename
storage firmware shelf show
storage iscsi-initiator commands
storage iscsi-initiator add-target
storage iscsi-initiator connect
storage iscsi-initiator disconnect
storage iscsi-initiator remove-target
storage iscsi-initiator show
storage path commands
storage path quiesce
storage path resume
storage path show-by-initiator
storage path show
storage pool commands
storage pool add
storage pool create
storage pool delete
storage pool reassign
storage pool rename
storage pool show-aggregate
storage pool show-available-capacity
storage pool show-disks
storage pool show
storage port commands
storage port disable
storage port enable
storage port modify
storage port rescan
storage port reset-device
storage port reset
storage port show
storage raid-options commands
storage raid-options modify
storage raid-options show
storage shelf commands
storage shelf show
storage shelf acp configure
storage shelf acp show
storage shelf acp module show
storage shelf drawer show-phy
storage shelf drawer show-slot
storage shelf firmware show-update-status
storage shelf firmware update
storage shelf location-led modify
storage shelf location-led show
storage shelf port show
storage tape commands
storage tape offline
storage tape online
storage tape position
storage tape reset
storage tape show-errors
storage tape show-media-changer
storage tape show-supported-status
storage tape show-tape-drive
storage tape show
storage tape trace
storage tape alias clear
storage tape alias set
storage tape alias show
storage tape config-file delete
storage tape config-file get
storage tape config-file show
storage tape library config show
storage tape library path show-by-initiator
storage tape load-balance modify
storage tape load-balance show
system commands
system bridge commands
system bridge add
system bridge modify
system bridge refresh
system bridge remove
system bridge run-cli
system bridge show
system bridge config-dump collect
system bridge config-dump delete
system bridge config-dump show
system bridge coredump collect
system bridge coredump delete
system bridge coredump show
system bridge firmware update
system bridge options modify
system bridge options show
system chassis commands
system chassis show
system chassis fru show
system configuration commands
system configuration backup copy
system configuration backup create
system configuration backup delete
system configuration backup download
system configuration backup rename
system configuration backup show
system configuration backup upload
system configuration backup settings modify
system configuration backup settings set-password
system configuration backup settings show
system configuration recovery cluster modify
system configuration recovery cluster recreate
system configuration recovery cluster rejoin
system configuration recovery cluster show
system configuration recovery cluster sync
system configuration recovery node restore
system controller commands
system controller show
system controller bootmedia show-serial-number
system controller clus-flap-threshold show
system controller config show-errors
system controller config pci show-add-on-devices
system controller config pci show-hierarchy
system controller coredump-device show-serial-number
system controller environment show
system controller flash-cache show
system controller flash-cache secure-erase run
system controller flash-cache secure-erase show
system controller fru show-manufacturing-info
system controller fru led disable-all
system controller fru led enable-all
system controller fru led modify
system controller fru led show
system controller hardware-license show
system controller hardware-license update
system controller ioxm show
system controller location-led modify
system controller location-led show
system controller memory dimm show
system controller nvram-bb-threshold show
system controller pci show
system controller pcicerr threshold modify
system controller pcicerr threshold show
system controller platform-capability show
system controller replace cancel
system controller replace pause
system controller replace resume
system controller replace show-details
system controller replace start
system controller service-event delete
system controller service-event show
system controller slot module insert
system controller slot module remove
system controller slot module replace
system controller slot module show
system controller sp config show
system controller sp upgrade show
system feature-usage commands
system feature-usage show-history
system feature-usage show-summary
system fru-check commands
system fru-check show
system ha commands
system ha interconnect config show
system ha interconnect link off
system ha interconnect link on
system ha interconnect ood clear-error-statistics
system ha interconnect ood clear-performance-statistics
system ha interconnect ood disable-optimization
system ha interconnect ood disable-statistics
system ha interconnect ood enable-optimization
system ha interconnect ood enable-statistics
system ha interconnect ood send-diagnostic-buffer
system ha interconnect ood status show
system ha interconnect port show
system ha interconnect statistics clear-port-symbol-error
system ha interconnect statistics show-scatter-gather-list
system ha interconnect statistics performance show
system ha interconnect status show
system health commands
system health alert delete
system health alert modify
system health alert show
system health alert definition show
system health autosupport trigger history show
system health config show
system health policy definition modify
system health policy definition show
system health status show
system health subsystem show
system license commands
system license add
system license clean-up
system license delete
system license show-aggregates
system license show-serial-numbers
system license show-status
system license show
system license update-leases
system license capacity show
system license entitlement-risk show
system license license-manager check
system license license-manager modify
system license license-manager show
system license status show
system node commands
system node halt
system node migrate-root
system node modify
system node reboot
system node rename
system node restore-backup
system node revert-to
system node run-console
system node run
system node show-discovered
system node show
system node autosupport invoke-core-upload
system node autosupport invoke-performance-archive
system node autosupport invoke-splog
system node autosupport modify
system node autosupport show
system node autosupport check show-details
system node autosupport destinations show
system node autosupport history cancel
system node autosupport history retransmit
system node autosupport history show-upload-details
system node autosupport manifest show
system node autosupport trigger modify
system node autosupport trigger show
system node coredump delete-all
system node coredump save-all
system node coredump show
system node coredump status
system node coredump trigger
system node coredump upload
system node coredump config modify
system node coredump config show
system node coredump external-device save
system node coredump external-device show
system node coredump reports delete
system node coredump reports show
system node coredump reports upload
system node coredump segment delete-all
system node coredump segment show
system node environment sensors show
system node external-cache modify
system node external-cache show
system node firmware download
system node hardware nvram-encryption modify
system node hardware nvram-encryption show
system node hardware tape drive show
system node hardware tape library show
system node hardware unified-connect modify
system node hardware unified-connect show
system node image abort-operation
system node image get
system node image modify
system node image show-update-progress
system node image update
system node image package delete
system node image package show
system node image package external-device delete
system node image package external-device show
system node internal-switch show
system node internal-switch dump stat
system node nfs usage show
system node power on
system node power show
system node root-mount create
system node root-mount delete
system node root-mount show
system node upgrade-revert show
system node upgrade-revert upgrade
system node usb-ports modify
system node usb-ports show
system node virtual-machine show-network-load-balancer
system node virtual-machine disk-object-store create
system node virtual-machine disk-object-store delete
system node virtual-machine disk-object-store modify
system node virtual-machine disk-object-store show
system node virtual-machine hypervisor show
system node virtual-machine instance show-system-disks
system script commands
system script delete
system script show
system script start
system script stop
system script upload
system service-processor commands
system service-processor reboot-sp
system service-processor show
system service-processor api-service disable-installed-certificates
system service-processor api-service enable-installed-certificates
system service-processor api-service modify
system service-processor api-service regenerate-ssh-auth-key
system service-processor api-service renew-internal-certificates
system service-processor api-service show
system service-processor image modify
system service-processor image show
system service-processor image update
system service-processor image update-progress show
system service-processor log show-allocations
system service-processor network modify
system service-processor network show
system service-processor network auto-configuration disable
system service-processor network auto-configuration enable
system service-processor network auto-configuration show
system service-processor ssh add-allowed-addresses
system service-processor ssh remove-allowed-addresses
system service-processor ssh show
system services commands
system services firewall modify
system services firewall show
system services firewall policy clone
system services firewall policy create
system services firewall policy delete
system services firewall policy modify
system services firewall policy show
system services manager install show
system services manager policy add
system services manager policy remove
system services manager policy setstate
system services manager policy show
system services manager status show
system services ndmp kill-all
system services ndmp modify
system services ndmp off
system services ndmp on
system services ndmp password
system services ndmp probe
system services ndmp show
system services ndmp status
system services ndmp log start
system services ndmp log stop
system services ndmp node-scope-mode off
system services ndmp node-scope-mode on
system services ndmp node-scope-mode status
system services ndmp service modify
system services ndmp service show
system services ndmp service start
system services ndmp service stop
system services ndmp service terminate
system services web modify
system services web show
system services web node show
system smtape commands
system smtape abort
system smtape backup
system smtape break
system smtape continue
system smtape restore
system smtape showheader
system smtape status clear
system smtape status show
system snmp commands
system snmp authtrap
system snmp contact
system snmp enable-snmpv3
system snmp init
system snmp location
system snmp prepare-to-downgrade
system snmp show
system snmp community add
system snmp community delete
system snmp community show
system snmp traphost add
system snmp traphost delete
system snmp traphost show
system status commands
system status show
system switch commands
system switch ethernet configure-health-monitor
system switch ethernet create
system switch ethernet delete
system switch ethernet modify
system switch ethernet show-all
system switch ethernet log collect
system switch ethernet log disable-collection
system switch ethernet log enable-collection
system switch ethernet log modify
system switch ethernet log setup-password
system switch ethernet log show
system switch ethernet polling-interval modify
system switch ethernet polling-interval show
system switch ethernet threshold show
system switch fibre-channel add
system switch fibre-channel modify
system switch fibre-channel refresh
system switch fibre-channel remove
system switch fibre-channel show
system timeout commands
system timeout modify
system timeout show
template commands
template copy
template delete
template download
template provision
template rename
template show-permissions
template show
template upload
template parameter commands
template parameter modify
template parameter show
volume commands
volume autosize
volume create
volume delete
volume expand
volume make-vsroot
volume modify
volume mount
volume offline
volume online
volume prepare-for-revert
volume rehost
volume rename
volume restrict
volume show-footprint
volume show-space
volume show
volume size
volume transition-prepare-to-downgrade
volume unmount
volume analytics commands
volume analytics off
volume analytics on
volume analytics show
volume clone commands
volume clone create
volume clone show
volume clone sharing-by-split show
volume clone sharing-by-split undo show
volume clone sharing-by-split undo start-all
volume clone sharing-by-split undo stop
volume clone split estimate
volume clone split show
volume clone split start
volume clone split stop
volume conversion commands
volume conversion start
volume conversion validation show
volume efficiency commands
volume efficiency check
volume efficiency modify
volume efficiency off
volume efficiency on
volume efficiency prepare-to-downgrade
volume efficiency promote
volume efficiency revert-to
volume efficiency show
volume efficiency start
volume efficiency stat
volume efficiency stop
volume efficiency undo
volume efficiency policy create
volume efficiency policy delete
volume efficiency policy modify
volume efficiency policy show
volume encryption commands
volume encryption conversion pause
volume encryption conversion resume
volume encryption conversion show
volume encryption conversion start
volume encryption rekey pause
volume encryption rekey resume
volume encryption rekey show
volume encryption rekey start
volume encryption secure-purge abort
volume encryption secure-purge show
volume encryption secure-purge start
volume file commands
volume file compact-data
volume file modify
volume file privileged-delete
volume file reservation
volume file show-disk-usage
volume file show-filehandle
volume file show-inode
volume file async-delete cancel
volume file async-delete prepare-for-revert
volume file async-delete show
volume file async-delete start
volume file clone autodelete
volume file clone create
volume file clone show-autodelete
volume file clone deletion add-extension
volume file clone deletion modify
volume file clone deletion remove-extension
volume file clone deletion show
volume file clone split load modify
volume file clone split load show
volume file fingerprint abort
volume file fingerprint dump
volume file fingerprint show
volume file fingerprint start
volume file retention show
volume flexcache commands
volume flexcache config-refresh
volume flexcache create
volume flexcache delete
volume flexcache prepare-to-downgrade
volume flexcache show
volume flexcache sync-properties
volume flexcache connection-status show
volume flexcache origin show-caches
volume flexcache origin config modify
volume flexcache origin config show
volume flexcache prepopulate start
volume flexgroup commands
volume flexgroup qtree-disable
volume inode-upgrade commands
volume inode-upgrade prepare-to-downgrade
volume inode-upgrade resume
volume inode-upgrade show
volume move commands
volume move abort
volume move modify
volume move show
volume move start
volume move trigger-cutover
volume move recommend show
volume move target-aggr show
volume object-store commands
volume object-store tiering show
volume object-store tiering trigger
volume qtree commands
volume qtree create
volume qtree delete
volume qtree modify
volume qtree oplocks
volume qtree rename
volume qtree security
volume qtree show
volume qtree statistics-reset
volume quota commands
volume quota modify
volume quota off
volume quota on
volume quota report
volume quota resize
volume quota show
volume quota policy copy
volume quota policy create
volume quota policy delete
volume quota policy rename
volume quota policy show
volume quota policy rule create
volume quota policy rule delete
volume quota policy rule modify
volume quota policy rule show
volume quota policy rule count show
volume reallocation commands
volume reallocation measure
volume reallocation off
volume reallocation on
volume reallocation quiesce
volume reallocation restart
volume reallocation schedule
volume reallocation show
volume reallocation start
volume reallocation stop
volume schedule-style commands
volume schedule-style prepare-to-downgrade
volume snaplock commands
volume snaplock modify
volume snaplock prepare-to-downgrade
volume snaplock show
volume snapshot commands
volume snapshot compute-reclaimable
volume snapshot create
volume snapshot delete
volume snapshot modify-snaplock-expiry-time
volume snapshot partial-restore-file
volume snapshot prepare-for-revert
volume snapshot rename
volume snapshot restore-file
volume snapshot show-delta
volume snapshot autodelete modify
volume snapshot autodelete show
volume snapshot policy add-schedule
volume snapshot policy create
volume snapshot policy delete
volume snapshot policy modify-schedule
volume snapshot policy remove-schedule
volume snapshot policy show
volume transition-convert-dir commands
volume transition-convert-dir show
volume transition-convert-dir start
vserver commands
vserver add-aggregates
vserver add-protocols
vserver context
vserver create
vserver delete
vserver modify
vserver prepare-for-revert
vserver remove-aggregates
vserver remove-protocols
vserver rename
vserver restamp-msid
vserver show-aggregates
vserver show-protocols
vserver show
vserver start
vserver stop
vserver unlock
vserver active-directory commands
vserver active-directory create
vserver active-directory delete
vserver active-directory modify
vserver active-directory password-change
vserver active-directory password-reset
vserver active-directory show
vserver audit commands
vserver audit create
vserver audit delete
vserver audit disable
vserver audit enable
vserver audit modify
vserver audit prepare-to-downgrade
vserver audit rotate-log
vserver audit show
vserver audit audit-log-redirect create
vserver audit audit-log-redirect delete
vserver audit audit-log-redirect modify
vserver audit audit-log-redirect show
vserver check commands
vserver check lif-multitenancy run
vserver check lif-multitenancy show-results
vserver cifs commands
vserver cifs add-netbios-aliases
vserver cifs check
vserver cifs create
vserver cifs delete
vserver cifs modify
vserver cifs nbtstat
vserver cifs prepare-to-downgrade
vserver cifs remove-netbios-aliases
vserver cifs repair-modify
vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
vserver cifs show
vserver cifs start
vserver cifs stop
vserver cifs branchcache create
vserver cifs branchcache delete
vserver cifs branchcache hash-create
vserver cifs branchcache hash-flush
vserver cifs branchcache modify
vserver cifs branchcache show
vserver cifs cache name-to-sid delete-all
vserver cifs cache name-to-sid show
vserver cifs cache settings modify
vserver cifs cache settings show
vserver cifs cache sid-to-name delete-all
vserver cifs cache sid-to-name show
vserver cifs character-mapping create
vserver cifs character-mapping delete
vserver cifs character-mapping modify
vserver cifs character-mapping show
vserver cifs connection show
vserver cifs domain discovered-servers reset-servers
vserver cifs domain discovered-servers show
vserver cifs domain discovered-servers discovery-mode modify
vserver cifs domain discovered-servers discovery-mode show
vserver cifs domain name-mapping-search add
vserver cifs domain name-mapping-search modify
vserver cifs domain name-mapping-search remove
vserver cifs domain name-mapping-search show
vserver cifs domain password change
vserver cifs domain password reset
vserver cifs domain password schedule modify
vserver cifs domain password schedule show
vserver cifs domain preferred-dc add
vserver cifs domain preferred-dc check
vserver cifs domain preferred-dc remove
vserver cifs domain preferred-dc show
vserver cifs domain trusts rediscover
vserver cifs domain trusts show
vserver cifs group-policy modify
vserver cifs group-policy show-applied
vserver cifs group-policy show-defined
vserver cifs group-policy update
vserver cifs group-policy central-access-policy show-applied
vserver cifs group-policy central-access-policy show-defined
vserver cifs group-policy central-access-rule show-applied
vserver cifs group-policy central-access-rule show-defined
vserver cifs group-policy restricted-group show-applied
vserver cifs group-policy restricted-group show-defined
vserver cifs home-directory modify
vserver cifs home-directory show-user
vserver cifs home-directory search-path add
vserver cifs home-directory search-path remove
vserver cifs home-directory search-path reorder
vserver cifs home-directory search-path show
vserver cifs options modify
vserver cifs options show
vserver cifs security modify
vserver cifs security show
vserver cifs session close
vserver cifs session show
vserver cifs session file close
vserver cifs session file show
vserver cifs share create
vserver cifs share delete
vserver cifs share modify
vserver cifs share show
vserver cifs share access-control create
vserver cifs share access-control delete
vserver cifs share access-control modify
vserver cifs share access-control show
vserver cifs share properties add
vserver cifs share properties remove
vserver cifs share properties show
vserver cifs superuser create
vserver cifs superuser delete
vserver cifs superuser show
vserver cifs symlink create
vserver cifs symlink delete
vserver cifs symlink modify
vserver cifs symlink show
vserver cifs users-and-groups remove-stale-records
vserver cifs users-and-groups update-names
vserver cifs users-and-groups local-group add-members
vserver cifs users-and-groups local-group create
vserver cifs users-and-groups local-group delete
vserver cifs users-and-groups local-group modify
vserver cifs users-and-groups local-group remove-members
vserver cifs users-and-groups local-group rename
vserver cifs users-and-groups local-group show-members
vserver cifs users-and-groups local-user create
vserver cifs users-and-groups local-user delete
vserver cifs users-and-groups local-user modify
vserver cifs users-and-groups local-user rename
vserver cifs users-and-groups local-user set-password
vserver cifs users-and-groups local-user show-membership
vserver cifs users-and-groups privilege add-privilege
vserver cifs users-and-groups privilege remove-privilege
vserver cifs users-and-groups privilege reset-privilege
vserver cifs users-and-groups privilege show
vserver config-replication commands
vserver config-replication pause
vserver config-replication resume
vserver config-replication show
vserver export-policy commands
vserver export-policy check-access
vserver export-policy copy
vserver export-policy create
vserver export-policy delete
vserver export-policy rename
vserver export-policy show
vserver export-policy access-cache flush
vserver export-policy access-cache show-rules
vserver export-policy access-cache config modify-all-vservers
vserver export-policy access-cache config show-all-vservers
vserver export-policy cache flush
vserver export-policy config-checker show
vserver export-policy config-checker start
vserver export-policy config-checker stop
vserver export-policy config-checker rule delete
vserver export-policy config-checker rule show
vserver export-policy netgroup check-membership
vserver export-policy netgroup cache show
vserver export-policy netgroup queue show
vserver export-policy rule add-clientmatches
vserver export-policy rule create
vserver export-policy rule delete
vserver export-policy rule modify
vserver export-policy rule remove-clientmatches
vserver export-policy rule setindex
vserver export-policy rule show
vserver fcp commands
vserver fcp create
vserver fcp delete
vserver fcp modify
vserver fcp show
vserver fcp start
vserver fcp stop
vserver fcp initiator show
vserver fcp interface show
vserver fcp nameserver show
vserver fcp ping-igroup show
vserver fcp ping-initiator show
vserver fcp portname set
vserver fcp portname show
vserver fcp topology show
vserver fcp wwn blacklist show
vserver fcp wwpn-alias remove
vserver fcp wwpn-alias set
vserver fcp wwpn-alias show
vserver fpolicy commands
vserver fpolicy disable
vserver fpolicy enable
vserver fpolicy engine-connect
vserver fpolicy engine-disconnect
vserver fpolicy show-enabled
vserver fpolicy show-engine
vserver fpolicy show-passthrough-read-connection
vserver fpolicy policy create
vserver fpolicy policy delete
vserver fpolicy policy modify
vserver fpolicy policy show
vserver fpolicy policy event create
vserver fpolicy policy event delete
vserver fpolicy policy event modify
vserver fpolicy policy event show
vserver fpolicy policy external-engine create
vserver fpolicy policy external-engine delete
vserver fpolicy policy external-engine modify
vserver fpolicy policy external-engine show
vserver fpolicy policy scope create
vserver fpolicy policy scope delete
vserver fpolicy policy scope modify
vserver fpolicy policy scope show
vserver http-proxy commands
vserver http-proxy create
vserver http-proxy delete
vserver http-proxy modify
vserver http-proxy show
vserver iscsi commands
vserver iscsi create
vserver iscsi delete
vserver iscsi modify
vserver iscsi show
vserver iscsi start
vserver iscsi stop
vserver iscsi command show
vserver iscsi connection show
vserver iscsi connection shutdown
vserver iscsi initiator show
vserver iscsi interface disable
vserver iscsi interface enable
vserver iscsi interface modify
vserver iscsi interface show
vserver iscsi interface accesslist add
vserver iscsi interface accesslist remove
vserver iscsi interface accesslist show
vserver iscsi isns create
vserver iscsi isns delete
vserver iscsi isns modify
vserver iscsi isns show
vserver iscsi isns start
vserver iscsi isns stop
vserver iscsi isns update
vserver iscsi security add-initator-address-ranges
vserver iscsi security create
vserver iscsi security default
vserver iscsi security delete
vserver iscsi security modify
vserver iscsi security prepare-to-downgrade
vserver iscsi security remove-initator-address-ranges
vserver iscsi security show
vserver iscsi session show
vserver iscsi session shutdown
vserver iscsi session parameter show
vserver locks commands
vserver locks break
vserver locks show
vserver name-mapping commands
vserver name-mapping create
vserver name-mapping delete
vserver name-mapping insert
vserver name-mapping modify
vserver name-mapping refresh-hostname-ip
vserver name-mapping show
vserver name-mapping swap
vserver nfs commands
vserver nfs create
vserver nfs delete
vserver nfs modify
vserver nfs off
vserver nfs on
vserver nfs prepare-for-v3-ms-dos-client-downgrade
vserver nfs prepare-to-downgrade
vserver nfs show
vserver nfs start
vserver nfs status
vserver nfs stop
vserver nfs connected-clients show
vserver nfs credentials count
vserver nfs credentials flush
vserver nfs credentials show
vserver nfs kerberos interface disable
vserver nfs kerberos interface enable
vserver nfs kerberos interface modify
vserver nfs kerberos interface show
vserver nfs kerberos realm create
vserver nfs kerberos realm delete
vserver nfs kerberos realm modify
vserver nfs kerberos realm show
vserver nfs pnfs devices create
vserver nfs pnfs devices delete
vserver nfs pnfs devices show
vserver nfs pnfs devices cache show
vserver nfs pnfs devices mappings show
vserver nvme commands
vserver nvme create
vserver nvme delete
vserver nvme modify
vserver nvme show-interface
vserver nvme show
vserver nvme feature show
vserver nvme namespace create
vserver nvme namespace delete
vserver nvme namespace modify
vserver nvme namespace show
vserver nvme subsystem create
vserver nvme subsystem delete
vserver nvme subsystem modify
vserver nvme subsystem show
vserver nvme subsystem controller show
vserver nvme subsystem host add
vserver nvme subsystem host remove
vserver nvme subsystem host show
vserver nvme subsystem map add
vserver nvme subsystem map remove
vserver nvme subsystem map show
vserver object-store-server commands
vserver object-store-server create
vserver object-store-server delete
vserver object-store-server modify
vserver object-store-server show
vserver object-store-server bucket create
vserver object-store-server bucket delete
vserver object-store-server bucket evict-remote-cached-objects
vserver object-store-server bucket modify
vserver object-store-server bucket show
vserver object-store-server bucket policy-statement-condition create
vserver object-store-server bucket policy-statement-condition delete
vserver object-store-server bucket policy-statement-condition modify
vserver object-store-server bucket policy-statement-condition show
vserver object-store-server bucket policy statement create
vserver object-store-server bucket policy statement delete
vserver object-store-server bucket policy statement modify
vserver object-store-server bucket policy statement show
vserver object-store-server group create
vserver object-store-server group delete
vserver object-store-server group modify
vserver object-store-server group show
vserver object-store-server policy create
vserver object-store-server policy delete
vserver object-store-server policy modify
vserver object-store-server policy show
vserver object-store-server policy statement create
vserver object-store-server policy statement delete
vserver object-store-server policy statement modify
vserver object-store-server policy statement show
vserver object-store-server user create
vserver object-store-server user delete
vserver object-store-server user modify
vserver object-store-server user regenerate-keys
vserver object-store-server user show
vserver peer commands
vserver peer accept
vserver peer create
vserver peer delete
vserver peer modify-local-name
vserver peer modify
vserver peer reject
vserver peer repair-peer-name
vserver peer resume
vserver peer show-all
vserver peer show
vserver peer suspend
vserver peer permission create
vserver peer permission delete
vserver peer permission modify
vserver peer permission show
vserver peer transition create
vserver peer transition delete
vserver peer transition modify
vserver peer transition show
vserver san commands
vserver san prepare-to-downgrade
vserver security commands
vserver security file-directory apply
vserver security file-directory remove-slag
vserver security file-directory show-effective-permissions
vserver security file-directory job show
vserver security file-directory ntfs create
vserver security file-directory ntfs delete
vserver security file-directory ntfs modify
vserver security file-directory ntfs show
vserver security file-directory ntfs dacl add
vserver security file-directory ntfs dacl modify
vserver security file-directory ntfs dacl remove
vserver security file-directory ntfs dacl show
vserver security file-directory ntfs sacl add
vserver security file-directory ntfs sacl modify
vserver security file-directory ntfs sacl remove
vserver security file-directory ntfs sacl show
vserver security file-directory policy create
vserver security file-directory policy delete
vserver security file-directory policy show
vserver security file-directory policy task add
vserver security file-directory policy task modify
vserver security file-directory policy task remove
vserver security file-directory policy task show
vserver security trace filter create
vserver security trace filter delete
vserver security trace filter modify
vserver security trace filter show
vserver security trace trace-result delete
vserver security trace trace-result show
vserver services commands
vserver services access-check authentication get-claim-name
vserver services access-check authentication get-dc-info
vserver services access-check authentication login-cifs
vserver services access-check authentication ontap-admin-login-cifs
vserver services access-check authentication show-creds
vserver services access-check authentication show-ontap-admin-unix-creds
vserver services access-check authentication sid-to-uid
vserver services access-check authentication sid-to-unix-name
vserver services access-check authentication translate
vserver services access-check authentication uid-to-sid
vserver services access-check dns forward-lookup
vserver services access-check dns srv-lookup
vserver services access-check name-mapping show
vserver services access-check server-discovery reset
vserver services access-check server-discovery show-host
vserver services access-check server-discovery show-site
vserver services access-check server-discovery test
vserver services name-service cache group-membership delete-all
vserver services name-service cache group-membership show
vserver services name-service cache group-membership settings modify
vserver services name-service cache group-membership settings show
vserver services name-service cache hosts forward-lookup delete-all
vserver services name-service cache hosts forward-lookup show
vserver services name-service cache hosts reverse-lookup delete-all
vserver services name-service cache hosts reverse-lookup show
vserver services name-service cache hosts settings modify
vserver services name-service cache hosts settings show
vserver services name-service cache netgroups ip-to-netgroup delete-all
vserver services name-service cache netgroups ip-to-netgroup show
vserver services name-service cache netgroups members delete-all
vserver services name-service cache netgroups members show
vserver services name-service cache netgroups settings modify
vserver services name-service cache netgroups settings show
vserver services name-service cache settings modify
vserver services name-service cache settings show
vserver services name-service cache unix-group group-by-gid delete-all
vserver services name-service cache unix-group group-by-gid show
vserver services name-service cache unix-group group-by-name delete-all
vserver services name-service cache unix-group group-by-name show
vserver services name-service cache unix-group settings modify
vserver services name-service cache unix-group settings show
vserver services name-service cache unix-user settings modify
vserver services name-service cache unix-user settings show
vserver services name-service cache unix-user user-by-id delete-all
vserver services name-service cache unix-user user-by-id show
vserver services name-service cache unix-user user-by-name delete-all
vserver services name-service cache unix-user user-by-name show
vserver services name-service dns check
vserver services name-service dns create
vserver services name-service dns delete
vserver services name-service dns modify
vserver services name-service dns show
vserver services name-service dns dynamic-update modify
vserver services name-service dns dynamic-update prepare-to-downgrade
vserver services name-service dns dynamic-update show
vserver services name-service dns dynamic-update record add
vserver services name-service dns dynamic-update record delete
vserver services name-service dns hosts create
vserver services name-service dns hosts delete
vserver services name-service dns hosts modify
vserver services name-service dns hosts show
vserver services name-service getxxbyyy getaddrinfo
vserver services name-service getxxbyyy getgrbygid
vserver services name-service getxxbyyy getgrbyname
vserver services name-service getxxbyyy getgrlist
vserver services name-service getxxbyyy gethostbyaddr
vserver services name-service getxxbyyy gethostbyname
vserver services name-service getxxbyyy getnameinfo
vserver services name-service getxxbyyy getpwbyname
vserver services name-service getxxbyyy getpwbyuid
vserver services name-service getxxbyyy netgrpcheck
vserver services name-service ldap check
vserver services name-service ldap create
vserver services name-service ldap delete
vserver services name-service ldap modify
vserver services name-service ldap show
vserver services name-service ldap client create
vserver services name-service ldap client delete
vserver services name-service ldap client modify-bind-password
vserver services name-service ldap client show
vserver services name-service ldap client schema copy
vserver services name-service ldap client schema delete
vserver services name-service ldap client schema modify
vserver services name-service ldap client schema show
vserver services name-service netgroup load
vserver services name-service netgroup status
vserver services name-service netgroup file delete
vserver services name-service netgroup file show
vserver services name-service nis-domain create
vserver services name-service nis-domain delete
vserver services name-service nis-domain modify
vserver services name-service nis-domain show-bound
vserver services name-service nis-domain group-database build
vserver services name-service nis-domain group-database status
vserver services name-service nis-domain netgroup-database build
vserver services name-service nis-domain netgroup-database show-status
vserver services name-service nis-domain netgroup-database config modify
vserver services name-service nis-domain netgroup-database config show
vserver services name-service ns-switch create
vserver services name-service ns-switch delete
vserver services name-service ns-switch modify
vserver services name-service ns-switch show
vserver services name-service unix-group adduser
vserver services name-service unix-group create
vserver services name-service unix-group delete
vserver services name-service unix-group deluser
vserver services name-service unix-group load-from-uri
vserver services name-service unix-group modify
vserver services name-service unix-group show
vserver services name-service unix-group file show
vserver services name-service unix-group file status
vserver services name-service unix-group max-limit modify
vserver services name-service unix-group max-limit show
vserver services name-service unix-user create
vserver services name-service unix-user delete
vserver services name-service unix-user load-from-uri
vserver services name-service unix-user modify
vserver services name-service unix-user show
vserver services name-service unix-user file show
vserver services name-service unix-user file status
vserver services name-service unix-user max-limit modify
vserver services name-service unix-user max-limit show
vserver services name-service ypbind start
vserver services name-service ypbind status
vserver services name-service ypbind stop
vserver services ndmp generate-password
vserver services ndmp kill-all
vserver services ndmp modify
vserver services ndmp off
vserver services ndmp on
vserver services ndmp probe
vserver services ndmp show
vserver services ndmp status
vserver services ndmp extensions modify
vserver services ndmp extensions show
vserver services ndmp log start
vserver services ndmp log stop
vserver services ndmp restartable-backup delete
vserver services ndmp restartable-backup show
vserver services web modify
vserver services web show
vserver services web access create
vserver services web access delete
vserver services web access show
vserver smtape commands
vserver smtape break
vserver snapdiff-rpc-server commands
vserver snapdiff-rpc-server off
vserver snapdiff-rpc-server on
vserver snapdiff-rpc-server show
vserver vscan commands
vserver vscan disable
vserver vscan enable
vserver vscan reset
vserver vscan show-events
vserver vscan show
vserver vscan connection-status show-all
vserver vscan connection-status show-connected
vserver vscan connection-status show-not-connected
vserver vscan on-access-policy create
vserver vscan on-access-policy delete
vserver vscan on-access-policy disable
vserver vscan on-access-policy enable
vserver vscan on-access-policy modify
vserver vscan on-access-policy show
vserver vscan on-access-policy file-ext-to-exclude add
vserver vscan on-access-policy file-ext-to-exclude remove
vserver vscan on-access-policy file-ext-to-exclude show
vserver vscan on-access-policy file-ext-to-include add
vserver vscan on-access-policy file-ext-to-include remove
vserver vscan on-access-policy file-ext-to-include show
vserver vscan on-access-policy paths-to-exclude add
vserver vscan on-access-policy paths-to-exclude remove
vserver vscan on-access-policy paths-to-exclude show
vserver vscan on-demand-task create
vserver vscan on-demand-task delete
vserver vscan on-demand-task modify
vserver vscan on-demand-task run
vserver vscan on-demand-task schedule
vserver vscan on-demand-task show
vserver vscan on-demand-task unschedule
vserver vscan on-demand-task report delete
vserver vscan on-demand-task report show
vserver vscan scanner-pool apply-policy
vserver vscan scanner-pool create
vserver vscan scanner-pool delete
vserver vscan scanner-pool modify
vserver vscan scanner-pool resolve-hostnames
vserver vscan scanner-pool show-active
vserver vscan scanner-pool privileged-users add
vserver vscan scanner-pool privileged-users remove
vserver vscan scanner-pool privileged-users show
vserver vscan scanner-pool servers add
vserver vscan scanner-pool servers remove
vserver vscan scanner-pool servers show
Legal notices
09/28/2023
