      system bridge coredump collect
Retrieve and save coredump
The system bridge coredump collect command retrieves a core file from a bridge.
- -name <text>- Bridge Name
This parameter specifies the bridge name from which the coredump file is to be collected.
The following example retrieves a coredump from bridge ATTO_FibreBridge7500N_1:
cluster1::> system bridge coredump collect -bridge ATTO_FibreBridge7500N_1 [Job 883] Job is queued: Collect the coredump from bridge "ATTO_FibreBridge7500N_1". cluster1::>
 PDFs
PDFs
