vserver fpolicy policy event show
Display events
The vserver fpolicy policy event show command displays information about all FPolicy events belonging to the Vserver. Any Vserver administrator can see FPolicy events associated with their Vserver as well as FPolicy events created by the cluster administrator. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all FPolicy events:
Vserver name
FPolicy event name
Protocol name
List of file operations
List of filters
Volume operation
You can specify the -fields parameter to specify which fields of information to display about FPolicy events. You can specify additional parameters to display only information that matches those parameters. For example, to display information only about all CIFS events configured with the -volume-operation field set, run the command with the -fields parameter set to -event-name event-name -protocol cifs-volume-operation yes .
You can specify the -instance parameter to display all information for all policies in a list format.
[-fields <fieldname>,…] -
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <Vserver Name>]- Vserver-
If you specify this parameter, the command displays information only about the FPolicy events for the specified Vserver. Events created on the admin Vserver by the cluster administrator are visible in all Vservers.
[-event-name <Event name>]- Event-
If you specify this parameter, the command displays information only about the FPolicy event that matches the specified event name.
[-protocol <Protocol>]- Protocol-
If you specify this parameter, the command displays information only about the FPolicy event or events that use the specified protocol.
[-file-operations <File Operation>,…]- File Operations-
If you specify this parameter, the command displays information only about the FPolicy event or events that use the specified file operation or operations.
[-filters <Filter>,…]- Filters-
If you specify this parameter, the command displays information only about the FPolicy event or events that use the specified filter or filters.
[-volume-operation {true|false}]- Send Volume Operation Notifications-
If this field is set to
true, then FPolicy displays information about those events for which it sends notifications when volumes are mounted or unmounted. If you set this parameter totrue, the command displays information about events where the-volume-operationparameter is settrueand volume operations such as mount and unmount are monitored. If you set this parameter tofalse, the command displays information about events where volume operations are not monitored.
The following example displays the information about all Vserver FPolicy policy events.
cluster1::> vserver fpolicy policy event show
Event File Volume
Vserver Name Protocols Operations Filters Operation
Cluster cserver_evt cifs open, close, first-write, true
read, write first-read
vs1.example.com cserver_evt cifs open, close, first-write, true
vs1.example.com v1e1 cifs open, read first-read -
vs1.example.com v1e2 cifs open - false
vs1.example.com v1e3 nfsv4 open - true
vs2.example.com cserver_evt cifs open, close, first-write, true
6 entries were displayed.
The following example displays event name information about all Vserver FPolicy policy events with CIFS as a protocol and with false as volume operation.
cluster1::> vserver fpolicy policy event show -fields event-name -protocol cifs -volume-operation false
vserver event-name
