• menu
  • netapp
  • Docs
  • All NetApp
    • BlueXP
    • Support
    • Knowledge Base
    • Training
  • All docs
  • ONTAP
ONTAP 9.8 commands
9.8
  • 9.8
  • 9.13.1
  • 9.12.1
  • 9.11.1
  • 9.10.1
  • 9.9.1
  • 9.7
  • 9.6
  • 9.5
  • 9.3
  • ONTAP 9.8 commands
  • exit
  • history
  • man
  • redo
  • rows
  • set
  • top
  • up
  • application commands
    • application provisioning commands
      • application provisioning config modify
      • application provisioning config show
  • autobalance commands
    • autobalance aggregate commands
      • autobalance aggregate show-aggregate-state
      • autobalance aggregate show-unbalanced-volume-state
      • autobalance aggregate config modify
      • autobalance aggregate config show
  • cluster commands
    • cluster add-node-status
    • cluster add-node
    • cluster create
    • cluster join
    • cluster modify
    • cluster ping-cluster
    • cluster remove-node
    • cluster setup
    • cluster show
    • cluster contact-info commands
      • cluster contact-info modify
      • cluster contact-info show
    • cluster controller-replacement commands
      • cluster controller-replacement network displaced-interface delete
      • cluster controller-replacement network displaced-interface restore-home-node
      • cluster controller-replacement network displaced-interface show
      • cluster controller-replacement network displaced-vlans delete
      • cluster controller-replacement network displaced-vlans restore
      • cluster controller-replacement network displaced-vlans show
    • cluster date commands
      • cluster date modify
      • cluster date show
      • cluster date zoneinfo load-from-uri
      • cluster date zoneinfo show
    • cluster ha commands
      • cluster ha modify
      • cluster ha show
    • cluster identity commands
      • cluster identity modify
      • cluster identity show
    • cluster image commands
      • cluster image cancel-update
      • cluster image pause-update
      • cluster image resume-update
      • cluster image show-update-history
      • cluster image show-update-log-detail
      • cluster image show-update-progress
      • cluster image update
      • cluster image validate
      • cluster image package delete
      • cluster image package get
      • cluster image package show-repository
    • cluster kernel-service commands
      • cluster kernel-service show
      • cluster kernel-service config modify
      • cluster kernel-service config show
    • cluster log-forwarding commands
      • cluster log-forwarding create
      • cluster log-forwarding delete
      • cluster log-forwarding modify
      • cluster log-forwarding show
    • cluster peer commands
      • cluster peer create
      • cluster peer delete
      • cluster peer modify-local-name
      • cluster peer ping
      • cluster peer show
      • cluster peer connection show
      • cluster peer health show
      • cluster peer offer cancel
      • cluster peer offer modify
      • cluster peer offer show
      • cluster peer policy modify
      • cluster peer policy show
    • cluster quorum-service commands
      • cluster quorum-service options modify
      • cluster quorum-service options show
    • cluster ring commands
      • cluster ring show
    • cluster statistics commands
      • cluster statistics show
    • cluster time-service commands
      • cluster time-service ntp key create
      • cluster time-service ntp key delete
      • cluster time-service ntp key modify
      • cluster time-service ntp key show
      • cluster time-service ntp security modify
      • cluster time-service ntp security show
      • cluster time-service ntp server create
      • cluster time-service ntp server delete
      • cluster time-service ntp server modify
      • cluster time-service ntp server reset
      • cluster time-service ntp server show
      • cluster time-service ntp status show
  • event commands
    • event catalog commands
      • event catalog show
    • event config commands
      • event config force-sync
      • event config modify
      • event config set-proxy-password
      • event config show
    • event destination commands
      • event destination create
      • event destination delete
      • event destination modify
      • event destination show
    • event filter commands
      • event filter copy
      • event filter create
      • event filter delete
      • event filter rename
      • event filter show
      • event filter test
      • event filter rule add
      • event filter rule delete
      • event filter rule reorder
    • event log commands
      • event log show
    • event mailhistory commands
      • event mailhistory delete
      • event mailhistory show
    • event notification commands
      • event notification create
      • event notification delete
      • event notification modify
      • event notification show
      • event notification destination create
      • event notification destination delete
      • event notification destination modify
      • event notification destination show
      • event notification history show
    • event route commands
      • event route add-destinations
      • event route modify
      • event route remove-destinations
      • event route show
    • event snmphistory commands
      • event snmphistory delete
      • event snmphistory show
    • event status commands
      • event status show
  • job commands
    • job delete
    • job pause
    • job resume
    • job show-bynode
    • job show-cluster
    • job show-completed
    • job show
    • job stop
    • job unclaim
    • job watch-progress
    • job history commands
      • job history show
    • job initstate commands
      • job initstate show
    • job private commands
      • job private delete
      • job private pause
      • job private resume
      • job private show-completed
      • job private show
      • job private stop
      • job private watch-progress
    • job schedule commands
      • job schedule delete
      • job schedule show-jobs
      • job schedule show
      • job schedule cron create
      • job schedule cron delete
      • job schedule cron modify
      • job schedule cron show
      • job schedule interval create
      • job schedule interval delete
      • job schedule interval modify
      • job schedule interval show
  • lun commands
    • lun create
    • lun delete
    • lun maxsize
    • lun modify
    • lun move-in-volume
    • lun resize
    • lun show
    • lun bind commands
      • lun bind create
      • lun bind destroy
      • lun bind show
    • lun copy commands
      • lun copy cancel
      • lun copy modify
      • lun copy pause
      • lun copy resume
      • lun copy show
      • lun copy start
    • lun igroup commands
      • lun igroup add
      • lun igroup bind
      • lun igroup create
      • lun igroup delete
      • lun igroup disable-aix-support
      • lun igroup modify
      • lun igroup remove
      • lun igroup rename
      • lun igroup show
      • lun igroup unbind
    • lun import commands
      • lun import create
      • lun import delete
      • lun import pause
      • lun import prepare-to-downgrade
      • lun import resume
      • lun import show
      • lun import start
      • lun import stop
      • lun import throttle
      • lun import verify start
      • lun import verify stop
    • lun mapping commands
      • lun mapping add-reporting-nodes
      • lun mapping create
      • lun mapping delete
      • lun mapping remove-reporting-nodes
      • lun mapping show-initiator
      • lun mapping show
    • lun move commands
      • lun move cancel
      • lun move modify
      • lun move pause
      • lun move resume
      • lun move show
      • lun move start
    • lun persistent-reservation commands
      • lun persistent-reservation clear
      • lun persistent-reservation show
    • lun portset commands
      • lun portset add
      • lun portset create
      • lun portset delete
      • lun portset remove
      • lun portset show
    • lun transition commands
      • lun transition show
      • lun transition start
      • lun transition 7-mode delete
      • lun transition 7-mode show
  • metrocluster commands
    • metrocluster configure
    • metrocluster heal
    • metrocluster modify
    • metrocluster remove-dr-group
    • metrocluster show
    • metrocluster switchback
    • metrocluster switchover
    • metrocluster check commands
      • metrocluster check disable-periodic-check
      • metrocluster check enable-periodic-check
      • metrocluster check run
      • metrocluster check show
      • metrocluster check aggregate show
      • metrocluster check cluster show
      • metrocluster check config-replication show-aggregate-eligibility
      • metrocluster check config-replication show-capture-status
      • metrocluster check connection show
      • metrocluster check lif repair-placement
      • metrocluster check lif show
      • metrocluster check node show
      • metrocluster check volume show
    • metrocluster config-replication commands
      • metrocluster config-replication cluster-storage-configuration modify
      • metrocluster config-replication cluster-storage-configuration show
      • metrocluster config-replication resync-status show
    • metrocluster configuration-settings commands
      • metrocluster configuration-settings show-status
      • metrocluster configuration-settings calibration measure
      • metrocluster configuration-settings calibration show
      • metrocluster configuration-settings connection check
      • metrocluster configuration-settings connection connect
      • metrocluster configuration-settings connection disconnect
      • metrocluster configuration-settings connection show
      • metrocluster configuration-settings dr-group create
      • metrocluster configuration-settings dr-group delete
      • metrocluster configuration-settings dr-group show
      • metrocluster configuration-settings interface create
      • metrocluster configuration-settings interface delete
      • metrocluster configuration-settings interface show
      • metrocluster configuration-settings mediator add
      • metrocluster configuration-settings mediator remove
      • metrocluster configuration-settings mediator show
    • metrocluster interconnect commands
      • metrocluster interconnect adapter modify
      • metrocluster interconnect adapter show
      • metrocluster interconnect mirror show
      • metrocluster interconnect mirror multipath show
    • metrocluster node commands
      • metrocluster node show
    • metrocluster operation commands
      • metrocluster operation show
      • metrocluster operation history show
    • metrocluster transition commands
      • metrocluster transition disable
      • metrocluster transition enable
      • metrocluster transition show-mode
    • metrocluster vserver commands
      • metrocluster vserver recover-from-partial-switchback
      • metrocluster vserver recover-from-partial-switchover
      • metrocluster vserver resync
      • metrocluster vserver show
  • network commands
    • network ping
    • network ping6
    • network test-path
    • network traceroute
    • network traceroute6
    • network arp commands
      • network arp create
      • network arp delete
      • network arp show
      • network arp active-entry delete
      • network arp active-entry show
    • network bgp commands
      • network bgp config create
      • network bgp config delete
      • network bgp config modify
      • network bgp config show
      • network bgp defaults modify
      • network bgp defaults show
      • network bgp peer-group create
      • network bgp peer-group delete
      • network bgp peer-group modify
      • network bgp peer-group rename
      • network bgp peer-group show
      • network bgp vserver-status show
    • network cloud commands
      • network cloud routing-table create
      • network cloud routing-table delete
      • network cloud routing-table show
    • network connections commands
      • network connections active show-clients
      • network connections active show-lifs
      • network connections active show-protocols
      • network connections active show-services
      • network connections listening show
    • network device-discovery commands
      • network device-discovery show
    • network fcp commands
      • network fcp adapter modify
      • network fcp adapter show
      • network fcp topology show
      • network fcp zone show
    • network interface commands
      • network interface create
      • network interface delete
      • network interface migrate-all
      • network interface modify
      • network interface rename
      • network interface revert
      • network interface show
      • network interface start-cluster-check
      • network interface capacity show
      • network interface capacity details show
      • network interface check failover show
      • network interface dns-lb-stats show
      • network interface failover-groups add-targets
      • network interface failover-groups create
      • network interface failover-groups delete
      • network interface failover-groups modify
      • network interface failover-groups remove-targets
      • network interface failover-groups rename
      • network interface failover-groups show
      • network interface lif-weights show
      • network interface service show
      • network interface service-policy add-service
      • network interface service-policy clone
      • network interface service-policy create
      • network interface service-policy delete
      • network interface service-policy modify-service
      • network interface service-policy remove-service
      • network interface service-policy rename
      • network interface service-policy restore-defaults
      • network interface service-policy show
    • network ipspace commands
      • network ipspace create
      • network ipspace delete
      • network ipspace rename
      • network ipspace show
    • network ndp commands
      • network ndp default-router delete-all
      • network ndp default-router show
      • network ndp neighbor create
      • network ndp neighbor delete
      • network ndp neighbor show
      • network ndp neighbor active-entry delete
      • network ndp neighbor active-entry show
      • network ndp prefix delete-all
      • network ndp prefix show
    • network options commands
      • network options cluster-health-notifications modify
      • network options cluster-health-notifications show
      • network options detect-switchless-cluster modify
      • network options detect-switchless-cluster show
      • network options ipv6 modify
      • network options ipv6 show
      • network options load-balancing modify
      • network options load-balancing show
      • network options multipath-routing modify
      • network options multipath-routing show
      • network options port-health-monitor disable-monitors
      • network options port-health-monitor enable-monitors
      • network options port-health-monitor modify
      • network options port-health-monitor show
      • network options send-soa modify
      • network options send-soa show
      • network options switchless-cluster modify
      • network options switchless-cluster show
    • network port commands
      • network port delete
      • network port modify
      • network port show-address-filter-info
      • network port show
      • network port broadcast-domain add-ports
      • network port broadcast-domain create
      • network port broadcast-domain delete
      • network port broadcast-domain merge
      • network port broadcast-domain modify
      • network port broadcast-domain move
      • network port broadcast-domain remove-ports
      • network port broadcast-domain rename
      • network port broadcast-domain show
      • network port broadcast-domain split
      • network port ifgrp add-port
      • network port ifgrp create
      • network port ifgrp delete
      • network port ifgrp remove-port
      • network port ifgrp show
      • network port reachability repair
      • network port reachability scan
      • network port reachability show
      • network port vip create
      • network port vip delete
      • network port vip show
      • network port vlan create
      • network port vlan delete
      • network port vlan show
    • network qos-marking commands
      • network qos-marking modify
      • network qos-marking show
    • network route commands
      • network route create
      • network route delete
      • network route show-lifs
      • network route active-entry show
    • network subnet commands
      • network subnet add-ranges
      • network subnet create
      • network subnet delete
      • network subnet modify
      • network subnet remove-ranges
      • network subnet rename
      • network subnet show
    • network tcpdump commands
      • network tcpdump show
      • network tcpdump start
      • network tcpdump stop
      • network tcpdump trace delete
      • network tcpdump trace show
    • network test-link commands
      • network test-link run-test
      • network test-link show
      • network test-link start-server
      • network test-link stop-server
    • network tuning commands
      • network tuning icmp modify
      • network tuning icmp show
      • network tuning icmp6 modify
      • network tuning icmp6 show
      • network tuning tcp modify
      • network tuning tcp show
  • protection-type commands
    • protection-type show
  • qos commands
    • qos adaptive-policy-group commands
      • qos adaptive-policy-group create
      • qos adaptive-policy-group delete
      • qos adaptive-policy-group modify
      • qos adaptive-policy-group rename
      • qos adaptive-policy-group show
    • qos policy-group commands
      • qos policy-group create
      • qos policy-group delete
      • qos policy-group modify
      • qos policy-group rename
      • qos policy-group show
    • qos settings commands
      • qos settings throughput-floors-v2
      • qos settings cache modify
      • qos settings cache show
    • qos statistics commands
      • qos statistics characteristics show
      • qos statistics latency show
      • qos statistics performance show
      • qos statistics resource cpu show
      • qos statistics resource disk show
      • qos statistics volume characteristics show
      • qos statistics volume latency show
      • qos statistics volume performance show
      • qos statistics volume resource cpu show
      • qos statistics volume resource disk show
      • qos statistics workload characteristics show
      • qos statistics workload latency show
      • qos statistics workload performance show
      • qos statistics workload resource cpu show
      • qos statistics workload resource disk show
    • qos workload commands
      • qos workload delete
      • qos workload show
  • san commands
    • san config commands
      • san config show
  • security commands
    • security snmpusers
    • security audit commands
      • security audit modify
      • security audit show
      • security audit log show
    • security certificate commands
      • security certificate create
      • security certificate delete
      • security certificate generate-csr
      • security certificate install
      • security certificate print
      • security certificate rename
      • security certificate show-generated
      • security certificate show-truststore
      • security certificate show-user-installed
      • security certificate sign
      • security certificate ca-issued revoke
      • security certificate ca-issued show
      • security certificate config modify
      • security certificate config show
      • security certificate truststore check
      • security certificate truststore clear
      • security certificate truststore load
    • security config commands
      • security config modify
      • security config show
      • security config ocsp disable
      • security config ocsp enable
      • security config ocsp show
      • security config status show
    • security ipsec commands
      • security ipsec show-ikesa
      • security ipsec show-ipsecsa
      • security ipsec config modify
      • security ipsec config show
      • security ipsec policy create
      • security ipsec policy delete
      • security ipsec policy modify
      • security ipsec policy show
    • security key-manager commands
      • security key-manager add
      • security key-manager create-key
      • security key-manager delete-key-database
      • security key-manager delete-kmip-config
      • security key-manager prepare-to-downgrade
      • security key-manager query
      • security key-manager restore
      • security key-manager setup
      • security key-manager show-key-store
      • security key-manager update-passphrase
      • security key-manager backup show
      • security key-manager config modify
      • security key-manager config show
      • security key-manager external add-servers
      • security key-manager external disable
      • security key-manager external enable
      • security key-manager external modify-server
      • security key-manager external remove-servers
      • security key-manager external restore
      • security key-manager external show-status
      • security key-manager external azure disable
      • security key-manager external azure enable
      • security key-manager external azure rekey-external
      • security key-manager external azure rekey-internal
      • security key-manager external azure restore
      • security key-manager external azure show
      • security key-manager external azure update-client-secret
      • security key-manager external boot-interfaces modify
      • security key-manager external boot-interfaces show
      • security key-manager key create
      • security key-manager key delete
      • security key-manager key migrate
      • security key-manager key query
      • security key-manager key show
      • security key-manager onboard disable
      • security key-manager onboard enable
      • security key-manager onboard show-backup
      • security key-manager onboard sync
      • security key-manager onboard update-passphrase
      • security key-manager onboard verify-backup
    • security login commands
      • security login create
      • security login delete
      • security login expire-password
      • security login lock
      • security login modify
      • security login password-prepare-to-downgrade
      • security login show
      • security login unlock
      • security login whoami
      • security login banner modify
      • security login banner show
      • security login domain-tunnel create
      • security login domain-tunnel delete
      • security login domain-tunnel modify
      • security login domain-tunnel show
      • security login motd modify
      • security login motd show
      • security login publickey create
      • security login publickey delete
      • security login publickey load-from-uri
      • security login publickey modify
      • security login publickey show
      • security login rest-role create
      • security login rest-role delete
      • security login rest-role modify
      • security login rest-role show
      • security login role create
      • security login role delete
      • security login role modify
      • security login role prepare-to-downgrade
      • security login role show-ontapi
      • security login role config modify
      • security login role config reset
      • security login role config show
    • security protocol commands
      • security protocol modify
      • security protocol show
      • security protocol ssh modify
      • security protocol ssh show
    • security saml-sp commands
      • security saml-sp create
      • security saml-sp delete
      • security saml-sp modify
      • security saml-sp repair
      • security saml-sp show
      • security saml-sp status show
    • security session commands
      • security session kill-cli
      • security session show
      • security session limit create
      • security session limit delete
      • security session limit modify
      • security session limit show
      • security session limit application create
      • security session limit application delete
      • security session limit application modify
      • security session limit application show
      • security session limit location create
      • security session limit location delete
      • security session limit location modify
      • security session limit location show
      • security session limit request create
      • security session limit request delete
      • security session limit request modify
      • security session limit request show
      • security session limit user create
      • security session limit user delete
      • security session limit user modify
      • security session limit user show
      • security session limit vserver create
      • security session limit vserver delete
      • security session limit vserver modify
      • security session limit vserver show
      • security session request-statistics show-by-application
      • security session request-statistics show-by-location
      • security session request-statistics show-by-request
      • security session request-statistics show-by-user
      • security session request-statistics show-by-vserver
    • security ssh commands
      • security ssh add
      • security ssh modify
      • security ssh prepare-to-downgrade
      • security ssh remove
      • security ssh show
    • security ssl commands
      • security ssl modify
      • security ssl show
    • security tpm commands
      • security tpm show
  • snaplock commands
    • snaplock compliance-clock commands
      • snaplock compliance-clock initialize
      • snaplock compliance-clock show
      • snaplock compliance-clock ntp modify
      • snaplock compliance-clock ntp show
    • snaplock event-retention commands
      • snaplock event-retention abort
      • snaplock event-retention apply
      • snaplock event-retention show-vservers
      • snaplock event-retention policy create
      • snaplock event-retention policy delete
      • snaplock event-retention policy modify
      • snaplock event-retention policy show
    • snaplock legal-hold commands
      • snaplock legal-hold abort
      • snaplock legal-hold begin
      • snaplock legal-hold dump-files
      • snaplock legal-hold dump-litigations
      • snaplock legal-hold end
      • snaplock legal-hold show
    • snaplock log commands
      • snaplock log create
      • snaplock log delete
      • snaplock log modify
      • snaplock log show
      • snaplock log file archive
      • snaplock log file show
  • snapmirror commands
    • snapmirror abort
    • snapmirror break
    • snapmirror create
    • snapmirror delete
    • snapmirror initialize-ls-set
    • snapmirror list-destinations
    • snapmirror modify
    • snapmirror promote
    • snapmirror protect
    • snapmirror quiesce
    • snapmirror release
    • snapmirror restore
    • snapmirror resume
    • snapmirror resync
    • snapmirror set-options
    • snapmirror show-history
    • snapmirror show
    • snapmirror update-ls-set
    • snapmirror update
    • snapmirror config-replication commands
      • snapmirror config-replication cluster-storage-configuration modify
      • snapmirror config-replication cluster-storage-configuration show
      • snapmirror config-replication status show-aggregate-eligibility
      • snapmirror config-replication status show-communication
    • snapmirror failover commands
      • snapmirror failover show
      • snapmirror failover start
    • snapmirror mediator commands
      • snapmirror mediator add
      • snapmirror mediator remove
      • snapmirror mediator show
    • snapmirror object-store commands
      • snapmirror object-store profiler abort
      • snapmirror object-store profiler show
      • snapmirror object-store profiler start
    • snapmirror policy commands
      • snapmirror policy add-rule
      • snapmirror policy create
      • snapmirror policy delete
      • snapmirror policy modify-rule
      • snapmirror policy remove-rule
      • snapmirror policy show
    • snapmirror snapshot-owner commands
      • snapmirror snapshot-owner create
      • snapmirror snapshot-owner delete
      • snapmirror snapshot-owner show
  • statistics commands
    • statistics show-periodic
    • statistics show
    • statistics start
    • statistics stop
    • statistics aggregate commands
      • statistics aggregate show
    • statistics cache commands
      • statistics cache flash-pool show
    • statistics catalog commands
      • statistics catalog counter show
      • statistics catalog instance show
      • statistics catalog object show
    • statistics disk commands
      • statistics disk show
    • statistics lif commands
      • statistics lif show
    • statistics lun commands
      • statistics lun show
    • statistics namespace commands
      • statistics namespace show
    • statistics nfs commands
      • statistics nfs show-mount
      • statistics nfs show-nlm
      • statistics nfs show-statusmon
      • statistics nfs show-v3
      • statistics nfs show-v4
      • statistics nfs show-v41
    • statistics node commands
      • statistics node show
    • statistics oncrpc commands
      • statistics oncrpc show-rpc-calls
    • statistics port commands
      • statistics port fcp show
    • statistics preset commands
      • statistics preset delete
      • statistics preset modify
      • statistics preset show
      • statistics preset detail show
    • statistics qtree commands
      • statistics qtree show
    • statistics samples commands
      • statistics samples delete
      • statistics samples show
    • statistics settings commands
      • statistics settings modify
      • statistics settings show
    • statistics system commands
      • statistics system show
    • statistics top commands
      • statistics top client show
      • statistics top file show
    • statistics volume commands
      • statistics volume show
    • statistics vserver commands
      • statistics vserver show
    • statistics workload commands
      • statistics workload show
  • statistics-v1 commands
    • statistics-v1 nfs commands
      • statistics-v1 nfs show-mount
      • statistics-v1 nfs show-nlm
      • statistics-v1 nfs show-statusmon
      • statistics-v1 nfs show-v3
      • statistics-v1 nfs show-v4
      • statistics-v1 nfs show-v41
    • statistics-v1 protocol-request-size commands
      • statistics-v1 protocol-request-size show
  • storage-service commands
    • storage-service show
  • storage commands
    • storage aggregate commands
      • storage aggregate add-disks
      • storage aggregate auto-provision
      • storage aggregate create
      • storage aggregate delete
      • storage aggregate mirror
      • storage aggregate modify
      • storage aggregate offline
      • storage aggregate online
      • storage aggregate remove-stale-record
      • storage aggregate rename
      • storage aggregate restrict
      • storage aggregate scrub
      • storage aggregate show-auto-provision-progress
      • storage aggregate show-cumulated-efficiency
      • storage aggregate show-efficiency
      • storage aggregate show-resync-status
      • storage aggregate show-scrub-status
      • storage aggregate show-space
      • storage aggregate show-spare-disks
      • storage aggregate show-status
      • storage aggregate verify
      • storage aggregate efficiency show
      • storage aggregate efficiency stat
      • storage aggregate efficiency cross-volume-dedupe revert-to
      • storage aggregate efficiency cross-volume-dedupe show
      • storage aggregate efficiency cross-volume-dedupe start
      • storage aggregate efficiency cross-volume-dedupe stop
      • storage aggregate encryption show-key-id
      • storage aggregate inode-upgrade resume
      • storage aggregate inode-upgrade show
      • storage aggregate object-store attach
      • storage aggregate object-store mirror
      • storage aggregate object-store modify
      • storage aggregate object-store show-freeing-status
      • storage aggregate object-store show-resync-status
      • storage aggregate object-store show-space
      • storage aggregate object-store unmirror
      • storage aggregate object-store config create
      • storage aggregate object-store config delete
      • storage aggregate object-store config modify
      • storage aggregate object-store config rename
      • storage aggregate object-store config show
      • storage aggregate object-store profiler abort
      • storage aggregate object-store profiler show
      • storage aggregate object-store profiler start
      • storage aggregate plex delete
      • storage aggregate plex offline
      • storage aggregate plex online
      • storage aggregate plex show
      • storage aggregate reallocation quiesce
      • storage aggregate reallocation restart
      • storage aggregate reallocation schedule
      • storage aggregate reallocation show
      • storage aggregate reallocation start
      • storage aggregate reallocation stop
      • storage aggregate relocation show
      • storage aggregate relocation start
      • storage aggregate resynchronization modify
      • storage aggregate resynchronization show
      • storage aggregate resynchronization options modify
      • storage aggregate resynchronization options show
    • storage array commands
      • storage array modify
      • storage array remove
      • storage array rename
      • storage array show
      • storage array config show
      • storage array disk paths show
      • storage array port modify
      • storage array port remove
      • storage array port show
    • storage automated-working-set-analyzer commands
      • storage automated-working-set-analyzer show
      • storage automated-working-set-analyzer start
      • storage automated-working-set-analyzer stop
      • storage automated-working-set-analyzer volume show
    • storage disk commands
      • storage disk assign
      • storage disk fail
      • storage disk reassign
      • storage disk refresh-ownership
      • storage disk remove-reservation
      • storage disk removeowner
      • storage disk replace
      • storage disk set-foreign-lun
      • storage disk set-led
      • storage disk show
      • storage disk unfail
      • storage disk updatefirmware
      • storage disk zerospares
      • storage disk error show
      • storage disk firmware revert
      • storage disk firmware show-update-status
      • storage disk firmware update
      • storage disk option modify
      • storage disk option show
    • storage dqp commands
      • storage dqp show
    • storage encryption commands
      • storage encryption disk destroy
      • storage encryption disk modify
      • storage encryption disk revert-to-original-state
      • storage encryption disk sanitize
      • storage encryption disk show-status
    • storage errors commands
      • storage errors show
    • storage failover commands
      • storage failover giveback
      • storage failover modify
      • storage failover show-giveback
      • storage failover show-takeover
      • storage failover takeover
      • storage failover hwassist show
      • storage failover hwassist test
      • storage failover hwassist stats clear
      • storage failover hwassist stats show
      • storage failover internal-options show
      • storage failover mailbox-disk show
      • storage failover progress-table show
    • storage firmware commands
      • storage firmware download
      • storage firmware acp delete
      • storage firmware acp rename
      • storage firmware acp show
      • storage firmware disk delete
      • storage firmware disk rename
      • storage firmware disk show
      • storage firmware shelf delete
      • storage firmware shelf rename
      • storage firmware shelf show
    • storage iscsi-initiator commands
      • storage iscsi-initiator add-target
      • storage iscsi-initiator connect
      • storage iscsi-initiator disconnect
      • storage iscsi-initiator remove-target
      • storage iscsi-initiator show
    • storage path commands
      • storage path quiesce
      • storage path resume
      • storage path show-by-initiator
      • storage path show
    • storage pool commands
      • storage pool add
      • storage pool create
      • storage pool delete
      • storage pool reassign
      • storage pool rename
      • storage pool show-aggregate
      • storage pool show-available-capacity
      • storage pool show-disks
      • storage pool show
    • storage port commands
      • storage port disable
      • storage port enable
      • storage port modify
      • storage port rescan
      • storage port reset-device
      • storage port show
    • storage raid-options commands
      • storage raid-options modify
      • storage raid-options show
    • storage shelf commands
      • storage shelf show
      • storage shelf acp configure
      • storage shelf acp show
      • storage shelf acp module show
      • storage shelf drawer show-phy
      • storage shelf drawer show-slot
      • storage shelf firmware show-update-status
      • storage shelf firmware update
      • storage shelf location-led modify
      • storage shelf location-led show
      • storage shelf port show
    • storage tape commands
      • storage tape offline
      • storage tape online
      • storage tape position
      • storage tape reset
      • storage tape show-errors
      • storage tape show-media-changer
      • storage tape show-supported-status
      • storage tape show-tape-drive
      • storage tape show
      • storage tape trace
      • storage tape alias clear
      • storage tape alias set
      • storage tape alias show
      • storage tape config-file delete
      • storage tape config-file get
      • storage tape config-file show
      • storage tape library config show
      • storage tape library path show-by-initiator
      • storage tape load-balance modify
      • storage tape load-balance show
  • system commands
    • system bridge commands
      • system bridge add
      • system bridge modify
      • system bridge refresh
      • system bridge remove
      • system bridge run-cli
      • system bridge show
      • system bridge config-dump collect
      • system bridge config-dump delete
      • system bridge config-dump show
      • system bridge coredump collect
      • system bridge coredump delete
      • system bridge coredump show
      • system bridge firmware update
      • system bridge options modify
      • system bridge options show
    • system chassis commands
      • system chassis show
      • system chassis fru show
    • system configuration commands
      • system configuration backup copy
      • system configuration backup create
      • system configuration backup delete
      • system configuration backup download
      • system configuration backup rename
      • system configuration backup show
      • system configuration backup upload
      • system configuration backup settings modify
      • system configuration backup settings set-password
      • system configuration backup settings show
      • system configuration recovery cluster modify
      • system configuration recovery cluster recreate
      • system configuration recovery cluster rejoin
      • system configuration recovery cluster show
      • system configuration recovery cluster sync
      • system configuration recovery node restore
    • system controller commands
      • system controller show
      • system controller bootmedia show-serial-number
      • system controller clus-flap-threshold show
      • system controller config show-errors
      • system controller config pci show-add-on-devices
      • system controller config pci show-hierarchy
      • system controller coredump-device show-serial-number
      • system controller environment show
      • system controller flash-cache show
      • system controller flash-cache secure-erase run
      • system controller flash-cache secure-erase show
      • system controller fru show-manufacturing-info
      • system controller fru led disable-all
      • system controller fru led enable-all
      • system controller fru led modify
      • system controller fru led show
      • system controller hardware-license show
      • system controller hardware-license update
      • system controller ioxm show
      • system controller location-led modify
      • system controller location-led show
      • system controller memory dimm show
      • system controller nvram-bb-threshold show
      • system controller pci show
      • system controller pcicerr threshold modify
      • system controller pcicerr threshold show
      • system controller platform-capability show
      • system controller replace cancel
      • system controller replace pause
      • system controller replace resume
      • system controller replace show-details
      • system controller replace start
      • system controller service-event delete
      • system controller service-event show
      • system controller slot module insert
      • system controller slot module remove
      • system controller slot module replace
      • system controller slot module show
      • system controller sp config show
      • system controller sp upgrade show
    • system feature-usage commands
      • system feature-usage show-history
      • system feature-usage show-summary
    • system fru-check commands
      • system fru-check show
    • system ha commands
      • system ha interconnect config show
      • system ha interconnect link off
      • system ha interconnect link on
      • system ha interconnect ood clear-error-statistics
      • system ha interconnect ood clear-performance-statistics
      • system ha interconnect ood disable-optimization
      • system ha interconnect ood disable-statistics
      • system ha interconnect ood enable-optimization
      • system ha interconnect ood enable-statistics
      • system ha interconnect ood send-diagnostic-buffer
      • system ha interconnect ood status show
      • system ha interconnect port show
      • system ha interconnect statistics clear-port-symbol-error
      • system ha interconnect statistics show-scatter-gather-list
      • system ha interconnect statistics performance show
      • system ha interconnect status show
    • system health commands
      • system health alert delete
      • system health alert modify
      • system health alert show
      • system health alert definition show
      • system health autosupport trigger history show
      • system health config show
      • system health policy definition modify
      • system health policy definition show
      • system health status show
      • system health subsystem show
    • system license commands
      • system license add
      • system license clean-up
      • system license delete
      • system license show-aggregates
      • system license show-serial-numbers
      • system license show-status
      • system license update-leases
      • system license capacity show
      • system license entitlement-risk show
      • system license license-manager check
      • system license license-manager modify
      • system license license-manager show
      • system license status show
    • system node commands
      • system node halt
      • system node migrate-root
      • system node modify
      • system node reboot
      • system node rename
      • system node restore-backup
      • system node revert-to
      • system node run-console
      • system node run
      • system node show-discovered
      • system node show
      • system node autosupport invoke-core-upload
      • system node autosupport invoke-performance-archive
      • system node autosupport invoke-splog
      • system node autosupport modify
      • system node autosupport show
      • system node autosupport check show-details
      • system node autosupport destinations show
      • system node autosupport history cancel
      • system node autosupport history retransmit
      • system node autosupport history show-upload-details
      • system node autosupport manifest show
      • system node autosupport trigger modify
      • system node autosupport trigger show
      • system node coredump delete-all
      • system node coredump save-all
      • system node coredump show
      • system node coredump status
      • system node coredump trigger
      • system node coredump upload
      • system node coredump config modify
      • system node coredump config show
      • system node coredump external-device save
      • system node coredump external-device show
      • system node coredump reports delete
      • system node coredump reports show
      • system node coredump reports upload
      • system node coredump segment delete-all
      • system node coredump segment show
      • system node environment sensors show
      • system node external-cache modify
      • system node external-cache show
      • system node firmware download
      • system node hardware nvram-encryption modify
      • system node hardware nvram-encryption show
      • system node hardware tape drive show
      • system node hardware tape library show
      • system node hardware unified-connect modify
      • system node hardware unified-connect show
      • system node image abort-operation
      • system node image get
      • system node image modify
      • system node image show-update-progress
      • system node image update
      • system node image package delete
      • system node image package show
      • system node image package external-device delete
      • system node image package external-device show
      • system node internal-switch show
      • system node internal-switch dump stat
      • system node nfs usage show
      • system node power on
      • system node power show
      • system node root-mount create
      • system node root-mount delete
      • system node root-mount show
      • system node upgrade-revert show
      • system node upgrade-revert upgrade
      • system node usb-ports modify
      • system node usb-ports show
      • system node virtual-machine show-network-load-balancer
      • system node virtual-machine disk-object-store create
      • system node virtual-machine disk-object-store delete
      • system node virtual-machine disk-object-store modify
      • system node virtual-machine disk-object-store show
      • system node virtual-machine hypervisor show
      • system node virtual-machine instance show-system-disks
    • system script commands
      • system script delete
      • system script show
      • system script start
      • system script stop
      • system script upload
    • system service-processor commands
      • system service-processor reboot-sp
      • system service-processor show
      • system service-processor api-service disable-installed-certificates
      • system service-processor api-service enable-installed-certificates
      • system service-processor api-service modify
      • system service-processor api-service regenerate-ssh-auth-key
      • system service-processor api-service renew-internal-certificates
      • system service-processor api-service show
      • system service-processor image modify
      • system service-processor image show
      • system service-processor image update
      • system service-processor image update-progress show
      • system service-processor log show-allocations
      • system service-processor network modify
      • system service-processor network show
      • system service-processor network auto-configuration disable
      • system service-processor network auto-configuration enable
      • system service-processor network auto-configuration show
      • system service-processor ssh add-allowed-addresses
      • system service-processor ssh remove-allowed-addresses
      • system service-processor ssh show
    • system services commands
      • system services firewall modify
      • system services firewall show
      • system services firewall policy clone
      • system services firewall policy create
      • system services firewall policy delete
      • system services firewall policy modify
      • system services firewall policy show
      • system services manager install show
      • system services manager policy add
      • system services manager policy remove
      • system services manager policy setstate
      • system services manager policy show
      • system services manager status show
      • system services ndmp kill-all
      • system services ndmp modify
      • system services ndmp off
      • system services ndmp on
      • system services ndmp password
      • system services ndmp probe
      • system services ndmp show
      • system services ndmp status
      • system services ndmp log start
      • system services ndmp log stop
      • system services ndmp node-scope-mode off
      • system services ndmp node-scope-mode on
      • system services ndmp node-scope-mode status
      • system services ndmp service modify
      • system services ndmp service show
      • system services ndmp service start
      • system services ndmp service stop
      • system services ndmp service terminate
      • system services web modify
      • system services web show
      • system services web node show
    • system smtape commands
      • system smtape abort
      • system smtape backup
      • system smtape break
      • system smtape continue
      • system smtape restore
      • system smtape showheader
      • system smtape status clear
      • system smtape status show
    • system snmp commands
      • system snmp authtrap
      • system snmp contact
      • system snmp enable-snmpv3
      • system snmp init
      • system snmp location
      • system snmp prepare-to-downgrade
      • system snmp show
      • system snmp community add
      • system snmp community delete
      • system snmp community show
      • system snmp traphost add
      • system snmp traphost delete
      • system snmp traphost show
    • system status commands
      • system status show
    • system switch commands
      • system switch ethernet configure-health-monitor
      • system switch ethernet create
      • system switch ethernet delete
      • system switch ethernet modify
      • system switch ethernet show-all
      • system switch ethernet log collect
      • system switch ethernet log disable-collection
      • system switch ethernet log enable-collection
      • system switch ethernet log modify
      • system switch ethernet log setup-password
      • system switch ethernet log show
      • system switch ethernet polling-interval modify
      • system switch ethernet polling-interval show
      • system switch ethernet threshold show
      • system switch fibre-channel add
      • system switch fibre-channel modify
      • system switch fibre-channel refresh
      • system switch fibre-channel remove
      • system switch fibre-channel show
    • system timeout commands
      • system timeout modify
      • system timeout show
  • template commands
    • template copy
    • template delete
    • template download
    • template provision
    • template rename
    • template show-permissions
    • template show
    • template upload
    • template parameter commands
      • template parameter modify
      • template parameter show
  • volume commands
    • volume autosize
    • volume create
    • volume delete
    • volume expand
    • volume make-vsroot
    • volume modify
    • volume mount
    • volume offline
    • volume online
    • volume prepare-for-revert
    • volume rehost
    • volume rename
    • volume restrict
    • volume show-footprint
    • volume show-space
    • volume show
    • volume size
    • volume transition-prepare-to-downgrade
    • volume unmount
    • volume analytics commands
      • volume analytics off
      • volume analytics on
      • volume analytics show
    • volume clone commands
      • volume clone create
      • volume clone show
      • volume clone sharing-by-split show
      • volume clone sharing-by-split undo show
      • volume clone sharing-by-split undo start-all
      • volume clone sharing-by-split undo stop
      • volume clone split estimate
      • volume clone split show
      • volume clone split start
      • volume clone split stop
    • volume conversion commands
      • volume conversion start
      • volume conversion validation show
    • volume efficiency commands
      • volume efficiency check
      • volume efficiency modify
      • volume efficiency off
      • volume efficiency on
      • volume efficiency prepare-to-downgrade
      • volume efficiency promote
      • volume efficiency revert-to
      • volume efficiency show
      • volume efficiency start
      • volume efficiency stat
      • volume efficiency stop
      • volume efficiency undo
      • volume efficiency policy create
      • volume efficiency policy delete
      • volume efficiency policy modify
      • volume efficiency policy show
    • volume encryption commands
      • volume encryption conversion pause
      • volume encryption conversion resume
      • volume encryption conversion show
      • volume encryption conversion start
      • volume encryption rekey pause
      • volume encryption rekey resume
      • volume encryption rekey show
      • volume encryption rekey start
      • volume encryption secure-purge abort
      • volume encryption secure-purge show
      • volume encryption secure-purge start
    • volume file commands
      • volume file compact-data
      • volume file modify
      • volume file privileged-delete
      • volume file reservation
      • volume file show-disk-usage
      • volume file show-filehandle
      • volume file show-inode
      • volume file async-delete cancel
      • volume file async-delete prepare-for-revert
      • volume file async-delete show
      • volume file async-delete start
      • volume file clone autodelete
      • volume file clone create
      • volume file clone show-autodelete
      • volume file clone deletion add-extension
      • volume file clone deletion modify
      • volume file clone deletion remove-extension
      • volume file clone deletion show
      • volume file clone split load modify
      • volume file clone split load show
      • volume file fingerprint abort
      • volume file fingerprint dump
      • volume file fingerprint show
      • volume file fingerprint start
      • volume file retention show
    • volume flexcache commands
      • volume flexcache config-refresh
      • volume flexcache create
      • volume flexcache delete
      • volume flexcache prepare-to-downgrade
      • volume flexcache show
      • volume flexcache sync-properties
      • volume flexcache connection-status show
      • volume flexcache origin show-caches
      • volume flexcache origin config modify
      • volume flexcache origin config show
      • volume flexcache prepopulate start
    • volume flexgroup commands
      • volume flexgroup qtree-disable
    • volume inode-upgrade commands
      • volume inode-upgrade prepare-to-downgrade
      • volume inode-upgrade resume
      • volume inode-upgrade show
    • volume move commands
      • volume move abort
      • volume move modify
      • volume move show
      • volume move start
      • volume move trigger-cutover
      • volume move recommend show
      • volume move target-aggr show
    • volume object-store commands
      • volume object-store tiering show
      • volume object-store tiering trigger
    • volume qtree commands
      • volume qtree create
      • volume qtree delete
      • volume qtree modify
      • volume qtree oplocks
      • volume qtree rename
      • volume qtree security
      • volume qtree show
      • volume qtree statistics-reset
    • volume quota commands
      • volume quota modify
      • volume quota off
      • volume quota on
      • volume quota report
      • volume quota resize
      • volume quota show
      • volume quota policy copy
      • volume quota policy create
      • volume quota policy delete
      • volume quota policy rename
      • volume quota policy show
      • volume quota policy rule create
      • volume quota policy rule delete
      • volume quota policy rule modify
      • volume quota policy rule show
      • volume quota policy rule count show
    • volume reallocation commands
      • volume reallocation measure
      • volume reallocation off
      • volume reallocation on
      • volume reallocation quiesce
      • volume reallocation restart
      • volume reallocation schedule
      • volume reallocation show
      • volume reallocation start
      • volume reallocation stop
    • volume schedule-style commands
      • volume schedule-style prepare-to-downgrade
    • volume snaplock commands
      • volume snaplock modify
      • volume snaplock prepare-to-downgrade
      • volume snaplock show
    • volume snapshot commands
      • volume snapshot compute-reclaimable
      • volume snapshot create
      • volume snapshot delete
      • volume snapshot modify-snaplock-expiry-time
      • volume snapshot partial-restore-file
      • volume snapshot prepare-for-revert
      • volume snapshot rename
      • volume snapshot restore-file
      • volume snapshot show-delta
      • volume snapshot autodelete modify
      • volume snapshot autodelete show
      • volume snapshot policy add-schedule
      • volume snapshot policy create
      • volume snapshot policy delete
      • volume snapshot policy modify-schedule
      • volume snapshot policy remove-schedule
      • volume snapshot policy show
    • volume transition-convert-dir commands
      • volume transition-convert-dir show
      • volume transition-convert-dir start
  • vserver commands
    • vserver add-aggregates
    • vserver add-protocols
    • vserver context
    • vserver create
    • vserver delete
    • vserver modify
    • vserver prepare-for-revert
    • vserver remove-aggregates
    • vserver remove-protocols
    • vserver rename
    • vserver restamp-msid
    • vserver show-aggregates
    • vserver show-protocols
    • vserver show
    • vserver start
    • vserver stop
    • vserver unlock
    • vserver active-directory commands
      • vserver active-directory create
      • vserver active-directory delete
      • vserver active-directory modify
      • vserver active-directory password-change
      • vserver active-directory password-reset
      • vserver active-directory show
    • vserver audit commands
      • vserver audit create
      • vserver audit delete
      • vserver audit disable
      • vserver audit enable
      • vserver audit modify
      • vserver audit prepare-to-downgrade
      • vserver audit rotate-log
      • vserver audit show
      • vserver audit audit-log-redirect create
      • vserver audit audit-log-redirect delete
      • vserver audit audit-log-redirect modify
      • vserver audit audit-log-redirect show
    • vserver check commands
      • vserver check lif-multitenancy run
      • vserver check lif-multitenancy show-results
    • vserver cifs commands
      • vserver cifs add-netbios-aliases
      • vserver cifs check
      • vserver cifs create
      • vserver cifs delete
      • vserver cifs modify
      • vserver cifs nbtstat
      • vserver cifs prepare-to-downgrade
      • vserver cifs remove-netbios-aliases
      • vserver cifs repair-modify
      • vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
      • vserver cifs show
      • vserver cifs start
      • vserver cifs stop
      • vserver cifs branchcache create
      • vserver cifs branchcache delete
      • vserver cifs branchcache hash-create
      • vserver cifs branchcache hash-flush
      • vserver cifs branchcache modify
      • vserver cifs branchcache show
      • vserver cifs cache name-to-sid delete-all
      • vserver cifs cache name-to-sid show
      • vserver cifs cache settings modify
      • vserver cifs cache settings show
      • vserver cifs cache sid-to-name delete-all
      • vserver cifs cache sid-to-name show
      • vserver cifs character-mapping create
      • vserver cifs character-mapping delete
      • vserver cifs character-mapping modify
      • vserver cifs character-mapping show
      • vserver cifs connection show
      • vserver cifs domain discovered-servers reset-servers
      • vserver cifs domain discovered-servers show
      • vserver cifs domain discovered-servers discovery-mode modify
      • vserver cifs domain discovered-servers discovery-mode show
      • vserver cifs domain name-mapping-search add
      • vserver cifs domain name-mapping-search modify
      • vserver cifs domain name-mapping-search remove
      • vserver cifs domain name-mapping-search show
      • vserver cifs domain password change
      • vserver cifs domain password reset
      • vserver cifs domain password schedule modify
      • vserver cifs domain password schedule show
      • vserver cifs domain preferred-dc add
      • vserver cifs domain preferred-dc check
      • vserver cifs domain preferred-dc remove
      • vserver cifs domain preferred-dc show
      • vserver cifs domain trusts rediscover
      • vserver cifs domain trusts show
      • vserver cifs group-policy modify
      • vserver cifs group-policy show-applied
      • vserver cifs group-policy show-defined
      • vserver cifs group-policy update
      • vserver cifs group-policy central-access-policy show-applied
      • vserver cifs group-policy central-access-policy show-defined
      • vserver cifs group-policy central-access-rule show-applied
      • vserver cifs group-policy central-access-rule show-defined
      • vserver cifs group-policy restricted-group show-applied
      • vserver cifs group-policy restricted-group show-defined
      • vserver cifs home-directory modify
      • vserver cifs home-directory show-user
      • vserver cifs home-directory search-path add
      • vserver cifs home-directory search-path remove
      • vserver cifs home-directory search-path reorder
      • vserver cifs home-directory search-path show
      • vserver cifs options modify
      • vserver cifs options show
      • vserver cifs security modify
      • vserver cifs security show
      • vserver cifs session close
      • vserver cifs session show
      • vserver cifs session file close
      • vserver cifs session file show
      • vserver cifs share create
      • vserver cifs share delete
      • vserver cifs share modify
      • vserver cifs share show
      • vserver cifs share access-control create
      • vserver cifs share access-control delete
      • vserver cifs share access-control modify
      • vserver cifs share access-control show
      • vserver cifs share properties add
      • vserver cifs share properties remove
      • vserver cifs share properties show
      • vserver cifs superuser create
      • vserver cifs superuser delete
      • vserver cifs superuser show
      • vserver cifs symlink create
      • vserver cifs symlink delete
      • vserver cifs symlink modify
      • vserver cifs symlink show
      • vserver cifs users-and-groups remove-stale-records
      • vserver cifs users-and-groups update-names
      • vserver cifs users-and-groups local-group add-members
      • vserver cifs users-and-groups local-group create
      • vserver cifs users-and-groups local-group delete
      • vserver cifs users-and-groups local-group modify
      • vserver cifs users-and-groups local-group remove-members
      • vserver cifs users-and-groups local-group rename
      • vserver cifs users-and-groups local-group show-members
      • vserver cifs users-and-groups local-user create
      • vserver cifs users-and-groups local-user delete
      • vserver cifs users-and-groups local-user modify
      • vserver cifs users-and-groups local-user rename
      • vserver cifs users-and-groups local-user set-password
      • vserver cifs users-and-groups local-user show-membership
      • vserver cifs users-and-groups privilege add-privilege
      • vserver cifs users-and-groups privilege remove-privilege
      • vserver cifs users-and-groups privilege reset-privilege
      • vserver cifs users-and-groups privilege show
    • vserver config-replication commands
      • vserver config-replication pause
      • vserver config-replication resume
      • vserver config-replication show
    • vserver export-policy commands
      • vserver export-policy check-access
      • vserver export-policy copy
      • vserver export-policy create
      • vserver export-policy delete
      • vserver export-policy rename
      • vserver export-policy show
      • vserver export-policy access-cache flush
      • vserver export-policy access-cache show-rules
      • vserver export-policy access-cache config modify-all-vservers
      • vserver export-policy access-cache config show-all-vservers
      • vserver export-policy cache flush
      • vserver export-policy config-checker show
      • vserver export-policy config-checker start
      • vserver export-policy config-checker stop
      • vserver export-policy config-checker rule delete
      • vserver export-policy config-checker rule show
      • vserver export-policy netgroup check-membership
      • vserver export-policy netgroup cache show
      • vserver export-policy netgroup queue show
      • vserver export-policy rule add-clientmatches
      • vserver export-policy rule create
      • vserver export-policy rule delete
      • vserver export-policy rule modify
      • vserver export-policy rule remove-clientmatches
      • vserver export-policy rule setindex
      • vserver export-policy rule show
    • vserver fcp commands
      • vserver fcp create
      • vserver fcp delete
      • vserver fcp modify
      • vserver fcp show
      • vserver fcp start
      • vserver fcp stop
      • vserver fcp initiator show
      • vserver fcp interface show
      • vserver fcp nameserver show
      • vserver fcp ping-igroup show
      • vserver fcp ping-initiator show
      • vserver fcp portname set
      • vserver fcp portname show
      • vserver fcp topology show
      • vserver fcp wwn blacklist show
      • vserver fcp wwpn-alias remove
      • vserver fcp wwpn-alias set
      • vserver fcp wwpn-alias show
    • vserver fpolicy commands
      • vserver fpolicy disable
      • vserver fpolicy enable
      • vserver fpolicy engine-connect
      • vserver fpolicy engine-disconnect
      • vserver fpolicy show-enabled
      • vserver fpolicy show-engine
      • vserver fpolicy show-passthrough-read-connection
      • vserver fpolicy policy create
      • vserver fpolicy policy delete
      • vserver fpolicy policy modify
      • vserver fpolicy policy show
      • vserver fpolicy policy event create
      • vserver fpolicy policy event delete
      • vserver fpolicy policy event modify
      • vserver fpolicy policy event show
      • vserver fpolicy policy external-engine create
      • vserver fpolicy policy external-engine delete
      • vserver fpolicy policy external-engine modify
      • vserver fpolicy policy external-engine show
      • vserver fpolicy policy scope create
      • vserver fpolicy policy scope delete
      • vserver fpolicy policy scope modify
      • vserver fpolicy policy scope show
    • vserver http-proxy commands
      • vserver http-proxy create
      • vserver http-proxy delete
      • vserver http-proxy modify
      • vserver http-proxy show
    • vserver iscsi commands
      • vserver iscsi create
      • vserver iscsi delete
      • vserver iscsi modify
      • vserver iscsi show
      • vserver iscsi start
      • vserver iscsi stop
      • vserver iscsi command show
      • vserver iscsi connection show
      • vserver iscsi connection shutdown
      • vserver iscsi initiator show
      • vserver iscsi interface disable
      • vserver iscsi interface enable
      • vserver iscsi interface modify
      • vserver iscsi interface show
      • vserver iscsi interface accesslist add
      • vserver iscsi interface accesslist remove
      • vserver iscsi interface accesslist show
      • vserver iscsi isns create
      • vserver iscsi isns delete
      • vserver iscsi isns modify
      • vserver iscsi isns show
      • vserver iscsi isns start
      • vserver iscsi isns stop
      • vserver iscsi isns update
      • vserver iscsi security add-initator-address-ranges
      • vserver iscsi security create
      • vserver iscsi security default
      • vserver iscsi security delete
      • vserver iscsi security modify
      • vserver iscsi security prepare-to-downgrade
      • vserver iscsi security remove-initator-address-ranges
      • vserver iscsi security show
      • vserver iscsi session show
      • vserver iscsi session shutdown
      • vserver iscsi session parameter show
    • vserver locks commands
      • vserver locks break
      • vserver locks show
    • vserver name-mapping commands
      • vserver name-mapping create
      • vserver name-mapping delete
      • vserver name-mapping insert
      • vserver name-mapping modify
      • vserver name-mapping refresh-hostname-ip
      • vserver name-mapping show
      • vserver name-mapping swap
    • vserver nfs commands
      • vserver nfs create
      • vserver nfs delete
      • vserver nfs modify
      • vserver nfs off
      • vserver nfs on
      • vserver nfs prepare-for-v3-ms-dos-client-downgrade
      • vserver nfs prepare-to-downgrade
      • vserver nfs show
      • vserver nfs start
      • vserver nfs status
      • vserver nfs stop
      • vserver nfs connected-clients show
      • vserver nfs credentials count
      • vserver nfs credentials flush
      • vserver nfs credentials show
      • vserver nfs kerberos interface disable
      • vserver nfs kerberos interface enable
      • vserver nfs kerberos interface modify
      • vserver nfs kerberos interface show
      • vserver nfs kerberos realm create
      • vserver nfs kerberos realm delete
      • vserver nfs kerberos realm modify
      • vserver nfs kerberos realm show
      • vserver nfs pnfs devices create
      • vserver nfs pnfs devices delete
      • vserver nfs pnfs devices show
      • vserver nfs pnfs devices cache show
      • vserver nfs pnfs devices mappings show
    • vserver nvme commands
      • vserver nvme create
      • vserver nvme delete
      • vserver nvme modify
      • vserver nvme show-interface
      • vserver nvme show
      • vserver nvme feature show
      • vserver nvme namespace create
      • vserver nvme namespace delete
      • vserver nvme namespace modify
      • vserver nvme namespace show
      • vserver nvme subsystem create
      • vserver nvme subsystem delete
      • vserver nvme subsystem modify
      • vserver nvme subsystem show
      • vserver nvme subsystem controller show
      • vserver nvme subsystem host add
      • vserver nvme subsystem host remove
      • vserver nvme subsystem host show
      • vserver nvme subsystem map add
      • vserver nvme subsystem map remove
      • vserver nvme subsystem map show
    • vserver object-store-server commands
      • vserver object-store-server create
      • vserver object-store-server delete
      • vserver object-store-server modify
      • vserver object-store-server show
      • vserver object-store-server bucket create
      • vserver object-store-server bucket delete
      • vserver object-store-server bucket evict-remote-cached-objects
      • vserver object-store-server bucket modify
      • vserver object-store-server bucket show
      • vserver object-store-server bucket policy-statement-condition create
      • vserver object-store-server bucket policy-statement-condition delete
      • vserver object-store-server bucket policy-statement-condition modify
      • vserver object-store-server bucket policy-statement-condition show
      • vserver object-store-server bucket policy statement create
      • vserver object-store-server bucket policy statement delete
      • vserver object-store-server bucket policy statement modify
      • vserver object-store-server bucket policy statement show
      • vserver object-store-server group create
      • vserver object-store-server group delete
      • vserver object-store-server group modify
      • vserver object-store-server group show
      • vserver object-store-server policy create
      • vserver object-store-server policy delete
      • vserver object-store-server policy modify
      • vserver object-store-server policy show
      • vserver object-store-server policy statement create
      • vserver object-store-server policy statement delete
      • vserver object-store-server policy statement modify
      • vserver object-store-server policy statement show
      • vserver object-store-server user create
      • vserver object-store-server user delete
      • vserver object-store-server user modify
      • vserver object-store-server user regenerate-keys
      • vserver object-store-server user show
    • vserver peer commands
      • vserver peer accept
      • vserver peer create
      • vserver peer delete
      • vserver peer modify-local-name
      • vserver peer reject
      • vserver peer repair-peer-name
      • vserver peer resume
      • vserver peer show-all
      • vserver peer show
      • vserver peer suspend
      • vserver peer permission create
      • vserver peer permission delete
      • vserver peer permission modify
      • vserver peer permission show
      • vserver peer transition create
      • vserver peer transition delete
      • vserver peer transition modify
      • vserver peer transition show
    • vserver san commands
      • vserver san prepare-to-downgrade
    • vserver security commands
      • vserver security file-directory apply
      • vserver security file-directory remove-slag
      • vserver security file-directory show-effective-permissions
      • vserver security file-directory job show
      • vserver security file-directory ntfs create
      • vserver security file-directory ntfs delete
      • vserver security file-directory ntfs modify
      • vserver security file-directory ntfs show
      • vserver security file-directory ntfs dacl add
      • vserver security file-directory ntfs dacl modify
      • vserver security file-directory ntfs dacl remove
      • vserver security file-directory ntfs dacl show
      • vserver security file-directory ntfs sacl add
      • vserver security file-directory ntfs sacl modify
      • vserver security file-directory ntfs sacl remove
      • vserver security file-directory ntfs sacl show
      • vserver security file-directory policy create
      • vserver security file-directory policy delete
      • vserver security file-directory policy show
      • vserver security file-directory policy task add
      • vserver security file-directory policy task modify
      • vserver security file-directory policy task remove
      • vserver security file-directory policy task show
      • vserver security trace filter create
      • vserver security trace filter delete
      • vserver security trace filter modify
      • vserver security trace filter show
      • vserver security trace trace-result delete
      • vserver security trace trace-result show
    • vserver services commands
      • vserver services access-check authentication get-claim-name
      • vserver services access-check authentication get-dc-info
      • vserver services access-check authentication login-cifs
      • vserver services access-check authentication ontap-admin-login-cifs
      • vserver services access-check authentication show-creds
      • vserver services access-check authentication show-ontap-admin-unix-creds
      • vserver services access-check authentication sid-to-uid
      • vserver services access-check authentication sid-to-unix-name
      • vserver services access-check authentication translate
      • vserver services access-check authentication uid-to-sid
      • vserver services access-check dns forward-lookup
      • vserver services access-check dns srv-lookup
      • vserver services access-check name-mapping show
      • vserver services access-check server-discovery reset
      • vserver services access-check server-discovery show-host
      • vserver services access-check server-discovery show-site
      • vserver services access-check server-discovery test
      • vserver services name-service cache group-membership delete-all
      • vserver services name-service cache group-membership show
      • vserver services name-service cache group-membership settings modify
      • vserver services name-service cache group-membership settings show
      • vserver services name-service cache hosts forward-lookup delete-all
      • vserver services name-service cache hosts forward-lookup show
      • vserver services name-service cache hosts reverse-lookup delete-all
      • vserver services name-service cache hosts reverse-lookup show
      • vserver services name-service cache hosts settings modify
      • vserver services name-service cache hosts settings show
      • vserver services name-service cache netgroups ip-to-netgroup delete-all
      • vserver services name-service cache netgroups ip-to-netgroup show
      • vserver services name-service cache netgroups members delete-all
      • vserver services name-service cache netgroups members show
      • vserver services name-service cache netgroups settings modify
      • vserver services name-service cache netgroups settings show
      • vserver services name-service cache settings modify
      • vserver services name-service cache settings show
      • vserver services name-service cache unix-group group-by-gid delete-all
      • vserver services name-service cache unix-group group-by-gid show
      • vserver services name-service cache unix-group group-by-name delete-all
      • vserver services name-service cache unix-group group-by-name show
      • vserver services name-service cache unix-group settings modify
      • vserver services name-service cache unix-group settings show
      • vserver services name-service cache unix-user settings modify
      • vserver services name-service cache unix-user settings show
      • vserver services name-service cache unix-user user-by-id delete-all
      • vserver services name-service cache unix-user user-by-id show
      • vserver services name-service cache unix-user user-by-name delete-all
      • vserver services name-service cache unix-user user-by-name show
      • vserver services name-service dns check
      • vserver services name-service dns create
      • vserver services name-service dns delete
      • vserver services name-service dns modify
      • vserver services name-service dns show
      • vserver services name-service dns dynamic-update modify
      • vserver services name-service dns dynamic-update prepare-to-downgrade
      • vserver services name-service dns dynamic-update show
      • vserver services name-service dns dynamic-update record add
      • vserver services name-service dns dynamic-update record delete
      • vserver services name-service dns hosts create
      • vserver services name-service dns hosts delete
      • vserver services name-service dns hosts modify
      • vserver services name-service dns hosts show
      • vserver services name-service getxxbyyy getaddrinfo
      • vserver services name-service getxxbyyy getgrbygid
      • vserver services name-service getxxbyyy getgrbyname
      • vserver services name-service getxxbyyy getgrlist
      • vserver services name-service getxxbyyy gethostbyaddr
      • vserver services name-service getxxbyyy gethostbyname
      • vserver services name-service getxxbyyy getnameinfo
      • vserver services name-service getxxbyyy getpwbyname
      • vserver services name-service getxxbyyy getpwbyuid
      • vserver services name-service getxxbyyy netgrpcheck
      • vserver services name-service ldap check
      • vserver services name-service ldap create
      • vserver services name-service ldap delete
      • vserver services name-service ldap modify
      • vserver services name-service ldap show
      • vserver services name-service ldap client create
      • vserver services name-service ldap client delete
      • vserver services name-service ldap client modify-bind-password
      • vserver services name-service ldap client show
      • vserver services name-service ldap client schema copy
      • vserver services name-service ldap client schema delete
      • vserver services name-service ldap client schema modify
      • vserver services name-service ldap client schema show
      • vserver services name-service netgroup load
      • vserver services name-service netgroup status
      • vserver services name-service netgroup file delete
      • vserver services name-service netgroup file show
      • vserver services name-service nis-domain create
      • vserver services name-service nis-domain delete
      • vserver services name-service nis-domain modify
      • vserver services name-service nis-domain show-bound
      • vserver services name-service nis-domain group-database build
      • vserver services name-service nis-domain group-database status
      • vserver services name-service nis-domain netgroup-database build
      • vserver services name-service nis-domain netgroup-database show-status
      • vserver services name-service nis-domain netgroup-database config modify
      • vserver services name-service nis-domain netgroup-database config show
      • vserver services name-service ns-switch create
      • vserver services name-service ns-switch delete
      • vserver services name-service ns-switch modify
      • vserver services name-service ns-switch show
      • vserver services name-service unix-group adduser
      • vserver services name-service unix-group create
      • vserver services name-service unix-group delete
      • vserver services name-service unix-group deluser
      • vserver services name-service unix-group load-from-uri
      • vserver services name-service unix-group modify
      • vserver services name-service unix-group show
      • vserver services name-service unix-group file show
      • vserver services name-service unix-group file status
      • vserver services name-service unix-group max-limit modify
      • vserver services name-service unix-group max-limit show
      • vserver services name-service unix-user create
      • vserver services name-service unix-user delete
      • vserver services name-service unix-user load-from-uri
      • vserver services name-service unix-user modify
      • vserver services name-service unix-user show
      • vserver services name-service unix-user file show
      • vserver services name-service unix-user file status
      • vserver services name-service unix-user max-limit modify
      • vserver services name-service unix-user max-limit show
      • vserver services name-service ypbind start
      • vserver services name-service ypbind status
      • vserver services name-service ypbind stop
      • vserver services ndmp generate-password
      • vserver services ndmp kill-all
      • vserver services ndmp modify
      • vserver services ndmp off
      • vserver services ndmp on
      • vserver services ndmp probe
      • vserver services ndmp show
      • vserver services ndmp status
      • vserver services ndmp extensions modify
      • vserver services ndmp extensions show
      • vserver services ndmp log start
      • vserver services ndmp log stop
      • vserver services ndmp restartable-backup delete
      • vserver services ndmp restartable-backup show
      • vserver services web modify
      • vserver services web show
      • vserver services web access create
      • vserver services web access delete
      • vserver services web access show
    • vserver smtape commands
      • vserver smtape break
    • vserver snapdiff-rpc-server commands
      • vserver snapdiff-rpc-server off
      • vserver snapdiff-rpc-server on
      • vserver snapdiff-rpc-server show
    • vserver vscan commands
      • vserver vscan disable
      • vserver vscan enable
      • vserver vscan reset
      • vserver vscan show-events
