system controller location-led modify
PDF of this doc site
Creating your file...
Modify the location LED state of a controller
The system controller location-led modify
command modifies the current state of the location LED. When lit, the location LED can help you find the controller in the data center.
There is a blue location LED on every controller and on the front of the chassis. When you turn on the location LED for either controller, the chassis location LED automatically turns on. When both controller location LEDs are off, the chassis location LED automatically turns off.
After the location LED is turned on, it stays illuminated for 30 minutes and then automatically shuts off.
-node {<nodename>|local}
- Node-
Selects the location LED on the specified filers.
[-state {on|off}]
- LED State-
Modifies the state of the location LED on the filer.
The following example turns on the location LED:
cluster1::*> system controller location-led modify -node node1 -state on
Turn off Location LED.
cluster1::*> system controller location-led modify -node node1 -state off
