The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver vscan on-demand-task unschedule
PDF of this doc site
Creating your file...
Your file is ready
Unschedule an On-Demand task
The vserver vscan on-demand-task unschedule
command unschedules an On-Demand task.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to unschedule an On-Demand task.
-task-name <text>
- Task Name-
This parameter specifies the name of the On-Demand task that you want to unschedule.
The following example unschedules an On-Demand task:
cluster1::> vserver vscan on-demand-task unschedule -vserver vs1 -task-name t1 cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1 Vserver: vs1 Task Name: t1 List of Scan Paths: /test Report Directory Path: /report Job Schedule: - Max File Size Allowed for Scanning: 2GB File Paths Not to Scan: /vol1/cold-files/ File Extensions Not to Scan: mp3, mp4 File Extensions to Scan: * Scan Files with No Extension: true Request Service Timeout: 1m Cross Junction: true Directory Recursion: true Scan Priority: low Report Log Level: verbose
