vserver vscan on-access-policy paths-to-exclude remove
Remove from the list of paths to exclude
The vserver vscan on-access-policy paths-to-exclude remove command removes a path or a list of paths that are excluded from scanning from the specified policy name.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver containing the specified on-access policy from which you want to remove a path or list of paths that are excluded from scanning.
- -policy-name <Policy name>- Policy
This parameter specifies the name of the on-access policy from which you want to remove a path or a list of paths that are excluded from scanning.
- -paths-to-exclude <File path>,…- Paths Not to Scan
This parameter specifies the path or a list of paths that must be removed from the on-access policy.
The following example removes a list of paths that are excluded from scanning from the specified policy name:
cluster:> vserver vscan on-access-policy paths-to-exclude remove -vserver vs1
          -policy-name policy1 -paths-to-exclude \test\test2,\test\test3
cluster1:> vserver vscan on-access-policy paths-to-exclude show -vserver vs1
Vserver: vs1
                Policy: policy1
File-Paths Not to Scan: \test\test1
 PDFs
PDFs
