qos policy-group show
Display a list of policy groups
The qos policy-group show
command shows the current settings of the policy groups on a cluster. You can display a list of the policy groups and you can view detailed information about a specific policy group.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-policy-group <text>]
- Policy Group Name-
Selects the policy groups that match this parameter value
Policy groups define measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
[-vserver <vserver name>]
- Vserver-
[-uuid <UUID>]
- Uuid-
[-class <QoS Configuration Class>]
- Policy Group Class-
[-pgid <integer>]
- Policy Group ID-
This uniquely identifies the policy group
[-max-throughput <qos_tput>]
- Maximum Throughput-
A maximum throughput limit specifies the throughput (in IOPS or MB/s) that the policy group must not exceed.
[-min-throughput <qos_tput>]
- Minimum Throughput-
A minimum throughput specifies the desired performance level for a policy group.
[-num-workloads <integer>]
- Number of Workloads-
Selects the policy groups that match this parameter value.
[-throughput-policy <text>]
- Throughput Policy-
Selects the policy groups that match this parameter value. You can specify the throughput range in terms of IOPS or data rate. For example,
0-INF, 0-400IOPS, 0-200KB/s, 0-400MB/s
. [-is-shared {true|false}]
- Is Shared-
The shared value specifies whether the policy group is a shared policy group or not.
[-is-auto-generated {true|false}]
- Is Policy Auto Generated-
The auto-generated value specifies whether the policy group is an automatically generated policy group or not.
cluster1::> qos policy-group show Name Vserver Class Wklds Throughput ---------------- ----------- ------------ ----- ------------ pg1 vs4 user-defined 0 0-200IOPS pg2 vs0 user-defined 0 0-500IOPS pg5 vs0 user-defined 0 0-300IOPS pg6 vs0 user-defined 0 0-INF 4 entries were displayed.
The example above displays all policy groups on the cluster.
