volume flexcache show
Display cache relationships
The volume flexcache show command displays information about FlexCache volumes. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all FlexCache volumes:
Vserver name
Volume name
Size
Space guarantee
Origin Vserver
Origin volume
Origin cluster
To display detailed information about all FlexCache volumes, run the command with the -instance parameter.
[-fields <fieldname>,…] -
This specifies the fields that need to be displayed.
[-instance ]} -
If this parameter is specified, the command displays information about all values.
[-vserver <Vserver Name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about FlexCache volumes on the specified Vserver. [-volume <volume name>]- Cache Volume Name-
If this parameter is specified, the command displays detailed information about the specified FlexCache volume.
[-aggr-list <aggregate name>,…]- List of Aggregates for FlexGroup Constituents-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that are located on the specified list of storage aggregates.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Volume Size-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have the specified size. Size is the maximum amount of space a volume can consume from its associated aggregate(s), including user data, metadata, Snapshot copies, and Snapshot reserve. Note that for volumes without a
-space-guaranteeofvolume, the ability to fill the volume to this maximum size depends on the space available in the associated aggregate or aggregates. [-flexgroup-msid <integer>]- Cache Flexgroup MSID (privilege: advanced)-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have the specified FlexGroup master data-set ID.
[-origin-vserver <vserver name>]- Origin Vserver Name-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes which have a relationship with the specificed origin-vserver.
[-origin-vserver-uuid <UUID>]- Origin Vserver UUID (privilege: advanced)-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes which have a relationship with the origin-vserver UUID.
[-origin-volume <volume name>]- Origin Volume Name-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have a relationship with the specified origin-volume.
[-origin-volume-msid <integer>]- Origin Volume MSID (privilege: advanced)-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have a relationship with the specified origin master data set ID.
[-origin-cluster <Cluster name>]- Origin Cluster Name-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have a relationship with the specified origin-cluster.
[-junction-path <junction path>]- Cache Junction Path-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have the specified junction path.
[-create-time <Date>]- FlexCache Create Time-
If you specify this parameter, the command displays information only about the FlexCache volume or volumes for which the
create-timeoption matches the specified input. [-s, -space-guarantee {none|volume}]- Space Guarantee Style-
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have the specified space guarantee style.
[-relationship-type {Intravserver|Intervserver|Intercluster}]- Relationship Type (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the relationship type.
The following example displays information about all FlexCache volumes on the Vserver named "vs34":
cluster1::> flexcache show -vserver vs34
(volume flexcache show)
Vserver Volume Size Origin-Vserver Origin-Volume Origin-Cluster
vs34 fc1 800MB vs34 origin1 cluster-2
vs34 fc2 800MB vs34 origin1 cluster-2
2 entries were displayed.
The following example displays detailed information about a FlexCache volume named fc1 on an SVM named vs34:
cluster1::> flexcache show -vserver vs34 -volume fc1 -instance
Vserver: vs34
Cache Volume Name: fc1
List of Aggregates for FlexGroup Constituents: aggr34
Volume Size: 800MB
Cache Flexgroup MSID: 2155934574
Origin Vserver Name: vs34
Origin Vserver UUID: a8717aeb-2826-11e8-bf56-00505695f37a
Origin Volume Name: origin1
Origin Volume MSID: 2155934545
Origin Cluster Name: cluster-2
Cache Junction Path: -
FlexCache Create Time: Thu Aug 23 04:36:19 2018
Relationship Type: inter-vserver
