ONTAP 9.8 commands
system services ndmp service start
Start the NDMP service
The system services ndmp service start command starts the NDMP service daemon for a node. This is different from the system services ndmp on command. The system services ndmp on command enables the daemon to accept NDMP requests. The NDMP service daemon starts automatically on a node when it boots up. Use this command to start the NDMP service daemon that has been stopped by the system services ndmp service stop command.
-node {<nodename>|local} - Node (privilege: advanced)
The node on which the NDMP service needs to be started.
cluster1::*> system services ndmp service start -node node0
Starts the NDMP service on node0.
