lun mapping show
Lists the mappings between LUNs and initiator groups.
This command lists the mappings between LUNs and initiator groups.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Selects the LUN maps for the Vserver that matches the parameter value.
- { [-path <path>]- LUN Path
Selects the LUN maps for the LUN with the path that matches the parameter value. Examples of correct LUN paths are /vol/vol1/lun1and/vol/vol1/qtree1/lun1.
- | [-volume <volume name>]- Volume Name
Selects the LUN maps for the volumes that match the parameter value.
- [-qtree <qtree name>]- Qtree Name
Selects the LUN maps for the queue trees that match the parameter value.
- [-lun <text>]- LUN Name }
Selects the LUN maps for the LUNs with a name that matches the parameter value.
- [-g, -igroup <text>]- Igroup Name
Selects the LUN maps for the igroup that matches the parameter value.
- [-ostype <Initiator Group OS Type>]- Igroup OS Type
Selects the LUN maps for the initiator groups with the OS type that matches the parameter value.
- [-protocol <protocol_enum>]- Igroup Protocol Type
Selects the LUN maps for initiator groups with a protocol that matches the parameter value. Possible values include FCP, iSCSI, or mixed.
- [-lun-id <integer>]- LUN ID
Selects the LUN maps with a LUN ID that matches the parameter value.
- [-portset <text>]- Portset Binding Igroup
Selects the LUN maps for initiator groups bound to the portset that matches the parameter value.
- [-alua {true|false}]- ALUA
Selects the LUN maps with ALUA settings that match the parameter value.
- [-n, -initiators <text>,…]- Initiators
Selects the LUN maps for initiator groups containing the initiators that match the parameter value.
- [-node <nodename>]- LUN Node
Selects the LUN maps for nodes that match the parameter value.
- [-reporting-nodes <nodename>,…]- Reporting Nodes
Selects the LUN maps that match the parameter value.
cluster1::> lun mapping show Vserver Path Igroup LUN ID Protocol ---------- ---------------------------------------- ------- ------ -------- vs1 /vol/vol1/lun1 igroup1 10 mixed vs1 /vol/vol1/lun1 igroup2 4 mixed vs1 /vol/vol5/lun1 igroup3 6 mixed vs1 /vol/vol5/lun2 igroup3 1 mixed 4 entries were displayed.
The example above lists all of the mappings between LUNs and initiator groups and the LUN ID for each mapping.
 PDFs
PDFs
