template show
Display templates
The template show
command displays information about templates. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, then the command displays the following information about all the templates:
Template Name
Permission (
readonly
orreadwrite
To display detailed information about a single template, run the command with the -name
parameter. The detailed view provides all of the information in the previous list with the following additional information:
Parent Template Name
Version
UUID of the Template
To display detailed information about all templates, run the command with the -instance
parameter.
You can specify additional parameters to display information that matches only those parameters. For example, to display information only about templates with readonly permissions, run the command with the -permission readonly
parameter.
[-fields <fieldname>,…]
This parameter specifies the fields that need to be displayed.
[-instance ]
If this parameter is specified, the command displays information about all entries.
[-name <template name>]
- Name of the template-
If this parameter is specified, the command displays the detailed information about the template that matches the specified name.
[-permission <template_permission>]
- Permission-
If this parameter is specified, the command displays information about the template or templates that matches the specified permission.
[-parent-template <text>]
- Parent template name-
If this parameter is specified, the command displays information about the template or templates that matches the specified parent template name.
[-description <text>]
- Description-
If this parameter is specified, the command displays information about the template or templates that matches the specified description.
[-version <text>]
- Version-
If this parameter is specified, the command displays information about the template or templates that matches the specified version.
[-uuid <UUID>]
- UUID of the template-
If this parameter is specified, the command displays information about the template or templates that matches the specified uuid.
The following example displays information about all templates in the cluster:
cluster1::> template show Template Permission ---------------------------------- ---------- template1 readonly template2 readwrite
The following example displays detailed information about a template named template1:
cluster1::> template show -name template1 Name of the Template: template1 Permission: readonly Parent Template Name: - Description: Template to configure Vserver Environment Version: 1.0 UUID of the Template: c8dfeb58-b5c5-5697-a829-18d4ee0ba202
