The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume inode-upgrade prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Prepare volume to downgrade to a release earlier than Data ONTAP 9.0.0
The volume inode-upgrade prepare-to-downgrade
command prepares volumes to downgrade to a release earlier than Data ONTAP 9.0.0. It is used when there are still volumes in the middile of the inode upgrade process when revert is issued.
-node {<nodename>|local}
- Node Name (privilege: advanced)-
This specifies the node on which the command will run. Default is the local node.
The following example prepares volumes to revert to an earlier release.
cluster1::> volume inode-upgrade prepare-to-downgrade -node node1
