      volume inode-upgrade prepare-to-downgrade
Prepare volume to downgrade to a release earlier than Data ONTAP 9.0.0
The volume inode-upgrade prepare-to-downgrade command prepares volumes to downgrade to a release earlier than Data ONTAP 9.0.0. It is used when there are still volumes in the middile of the inode upgrade process when revert is issued.
- -node {<nodename>|local}- Node Name (privilege: advanced)
This specifies the node on which the command will run. Default is the local node.
The following example prepares volumes to revert to an earlier release.
cluster1::> volume inode-upgrade prepare-to-downgrade -node node1
 PDFs
PDFs
