storage aggregate resynchronization options show
Display node specific aggregate resynchronization options
The storage aggregate resynchronization options show command displays all the options that govern the resynchronization of aggregates on a given cluster node. If no parameters are specified, the command displays the following information about all nodes:
  • Node for which the information is being displayed
  • Maximum number of concurrent resynchronizing aggregates allowed
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, the command displays resynchronization options only for the specified node.
[-max-concurrent-resync <integer>] - Maximum Concurrent Resynchronizing Aggregates
If this parameter is specified, the command displays only the resynchronization option that matches the specified value.
The following example displays the maximum number of concurrent resyncs allowed for each node in the cluster:
cluster1::> storage aggregate resynchronization options show
Node          Maximum Concurrent Resynchronizing Aggregates
cluster1-01   15
cluster1-02    4
2 entries were displayed.
The following example displays the maximum number of concurrent resyncs allowed for a specified node:
cluster1::> storage aggregate resynchronization options show -node node1
cluster1-01   15
The following example displays all the nodes that allow more than five concurrent resync operations:
cluster1::> storage aggregate resynchronization options show -max-concurrent-resyncs >5
cluster1-01   15
