security audit modify
Set administrative audit logging settings
The security audit modify command modifies the following audit-logging settings for the management interface:
Whether get requests for the CLI are audited
Whether get requests for the Data ONTAP API (ONTAPI) are audited
[-cliget {on|off}]- Enable Auditing of CLI Get Operations-
This specifies whether get requests for the CLI are audited. The default setting is
off. [-httpget {on|off}]- Enable Auditing of HTTP Get Operations-
This specifies whether get requests for the web (HTTP) interface are audited. The default setting is
off. [-ontapiget {on|off}]- Enable Auditing of Data ONTAP API Get Operations-
This specifies whether get requests for the Data ONTAP API (ONTAPI) interface are audited. The default setting is
off.
The following example turns off auditing of get requests for the CLI interface:
cluster1::> security audit modify -cliget off
