      system license delete
Delete a license
This command deletes a license from a cluster.
-serial-number <text>- Serial Number-
This parameter specifies the serial number of the license that is to be deleted from the cluster. If this parameter is not provided, the default value is the serial number of the cluster.
 -package <Licensable Package>- Package-
This parameter specifies the name of the package that is to be deleted from the cluster.
The following example deletes a license named CIFS and serial number 1-81-0000000000000000000123456 from the cluster:
cluster1::> system license delete -serial-number 1-81-0000000000000000000123456 -package CIFS
