ONTAP 9.8 commands
network tcpdump show
Show running tcpdump instances
The network tcpdump show command shows currently running packet traces (via tcpdump) on a matching node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
Use this parameter optionally to show the details of running packet traces on a matching node.
[-port {<netport>|<ifgrp>}] - Port
Use this parameter optionally to show the details of running packet trace on a matching network interface.
The following example shows the details of running packet traces on nodes "node1" and "node2":
cluster1::> network tcpdump show
Node       Port
node1
           e0a
node2
           e0c
