ONTAP commands
volume clone sharing-by-split undo show
Show the status of volume clone undo-sharing operations in-progress
The volume clone sharing-by-split undo show command displays the progress information of undo-sharing in the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, the command displays the following information:
  • Vserver name
  • Volume name
  • Total number of blocks scanned for undo sharing
  • Total number of blocks present
  • Percentage of blocks processed
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
This parameter selects information about the ongoing undo-sharing scan for all volumes on this Vserver.
[-volume <volume name>] - Volume Name (privilege: advanced)
This parameter selects information about the ongoing undo-sharing scan on this volume.
[-blocks-scanned <integer>] - Scanned Blocks (privilege: advanced)
This parameter selects information about the total number of blocks scanned by undo-sharing in the given volume.
[-blocks-total <integer>] - Total Blocks (privilege: advanced)
This parameter selects information about the total number of blocks for the undo-sharing to scan in the given volume.
[-blocks-percentage-complete <integer>] - Blocks Percentage Complete (privilege: advanced)
This parameter selects information about the percentage of block processing completed by undo-sharing in the given volume.
The following example displays information about all the ongoing undo-sharing scan in the cluster:
cluster1::> volume clone sharing-by-split undo show
                            Blocks     Blocks      Blocks
Vserver   Volume           Scanned      Total  % Complete
vs1       vol_clone1             0       1260           0
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split undo show -vserver vs1 -volume vol_clone1 -instance
Vserver Name: vs1
        Volume Name: vol_clone1
           Blocks Scanned: 0
             Blocks Total: 1260
Block Percentage complete: 0
