volume clone sharing-by-split undo show
Show the status of volume clone undo-sharing operations in-progress
The volume clone sharing-by-split undo show command displays the progress information of undo-sharing in the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, the command displays the following information:
Vserver name
Volume name
Total number of blocks scanned for undo sharing
Total number of blocks present
Percentage of blocks processed
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)
This parameter selects information about the ongoing undo-sharing scan for all volumes on this Vserver.
- [-volume <volume name>]- Volume Name (privilege: advanced)
This parameter selects information about the ongoing undo-sharing scan on this volume.
- [-blocks-scanned <integer>]- Scanned Blocks (privilege: advanced)
This parameter selects information about the total number of blocks scanned by undo-sharing in the given volume.
- [-blocks-total <integer>]- Total Blocks (privilege: advanced)
This parameter selects information about the total number of blocks for the undo-sharing to scan in the given volume.
- [-blocks-percentage-complete <integer>]- Blocks Percentage Complete (privilege: advanced)
This parameter selects information about the percentage of block processing completed by undo-sharing in the given volume.
The following example displays information about all the ongoing undo-sharing scan in the cluster:
cluster1::> volume clone sharing-by-split undo show
                            Blocks     Blocks      Blocks
Vserver   Volume           Scanned      Total  % Complete
vs1       vol_clone1             0       1260           0
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split undo show -vserver vs1 -volume vol_clone1 -instance
Vserver Name: vs1
        Volume Name: vol_clone1
           Blocks Scanned: 0
             Blocks Total: 1260
Block Percentage complete: 0
 PDFs
PDFs
