storage failover show-giveback
Display giveback status
The storage failover show-giveback
command displays information about the giveback status of high-availability (HA) partner aggregates. The command displays the following information when no parameters are specified:
Node name
Partner aggregate name
Giveback Status
You can specify additional parameters to display only the information that matches those parameters. For example, to display information only about a particular aggregate, run the command with the `-aggregate aggregate_name ` parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If this parameter is used, the command displays information about the giveback status of the aggregates belonging to the HA partner of the specified node.
[-aggregate <text>]
- Aggregate-
If this parameter is used, the command displays information about the giveback status of the specified aggregate.
[-giveback-status <text>,…]
- Aggregates Giveback State-
If this parameter is used, the command displays information about the aggregates with the specified giveback status.
[-destination <text>]
- Destination for Giveback-
If this parameter is used, the command displays information about the giveback status of the aggregates whose destination after the giveback is the specified node.
The following example displays information about giveback status on all nodes:
node::> storage failover show-giveback Partner Node Aggregate Giveback Status -------------- ----------------- ------------------------------------------- node0 - No aggregates to give back node1 - No aggregates to give back node2 - No aggregates to give back node3 - No aggregates to give back 4 entries were displayed.
