ONTAP commands
storage failover show-giveback
Display giveback status
The storage failover show-giveback command displays information about the giveback status of high-availability (HA) partner aggregates. The command displays the following information when no parameters are specified:
  • Node name
  • Partner aggregate name
  • Giveback Status
    You can specify additional parameters to display only the information that matches those parameters. For example, to display information only about a particular aggregate, run the command with the `-aggregate aggregate_name ` parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is used, the command displays information about the giveback status of the aggregates belonging to the HA partner of the specified node.
[-aggregate <text>] - Aggregate
If this parameter is used, the command displays information about the giveback status of the specified aggregate.
[-giveback-status <text>,…​] - Aggregates Giveback State
If this parameter is used, the command displays information about the aggregates with the specified giveback status.
[-destination <text>] - Destination for Giveback
If this parameter is used, the command displays information about the giveback status of the aggregates whose destination after the giveback is the specified node.
The following example displays information about giveback status on all nodes:
node::> storage failover show-giveback
               Partner
Node           Aggregate         Giveback Status
node0
               -                 No aggregates to give back
node1
node2
node3
4 entries were displayed.
