ONTAP commands
network interface capacity show
Display the number of IP data LIFs capable of being configured on the cluster.
The network interface capacity show command displays the number of IP LIFs of role data supported on the cluster, as well as the number of IP LIFs of role data currently configured on the cluster.
Note The number of IP LIFs of role data that are supported on a node depends on the hardware platform and the Cluster's Data ONTAP version. If one or more nodes in the cluster cannot support additional LIFs, then none of the nodes in the cluster can support additional LIFs.
The following displays the IP data LIF capacity.
cluster1::> network interface capacity show
      IP Data LIF      IP Data LIF
  Supported Limit            Count
             1024              256
