security key-manager external show
Show the set of configured external key management servers
This command displays the external key management servers configured on the cluster for a given Vserver. No entries are displayed when external key management is not enabled for the given Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If you specify this parameter, then the command displays the key management servers for only the given Vserver.
[-key-server <text>]- Key Server Name with port-
If you specify this parameter, then the command displays only the given key management server with the given host name or IP address listening on the given port.
[-client-cert <text>]- Name of the Client Certificate-
If you specify this parameter, then the command displays only the key management servers using a client certificate with the given name.
[-server-ca-certs <text>,…]- Names of the Server CA Certificates-
If you specify this parameter, then the command displays only the key management servers using server-ca certificates with the given names.
[-timeout <integer>]- Server I/O Timeout-
If you specify this parameter, then the command displays only the key management servers using the given I/O timeout.
[-username <text>]- Authentication User Name-
If you specify this parameter, then the command displays only the key management servers using the given authentication username.
The following example lists all configured key management servers for all Vservers:
cluster-1::> security key-manager external show
Vserver: datavs
Client Certificate: datavsClientCert
Server CA Certificates: datavsServerCaCert1, datavsServerCaCert2
Key Server
keyserver.datavs.com:5696
Vserver: cluster-1
Client Certificate: AdminClientCert
Server CA Certificates: AdminServerCaCert
Key Server
10.0.0.10:1234
fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234
ks1.local:1234
4 entries were displayed.
The following example lists all configured key management servers with more detail, including timeouts and usernames:
cluster-1::> security key-manager external show -instance
Vserver: datavs
Key Server: keyserver.datavs.com:5696
Timeout: 25
Username: datavsuser
Vserver: cluster-1
Key Server: 10.0.0.10:1234
Timeout: 25
Username:
Vserver: cluster-1
Key Server: fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234
Timeout: 25
Username:
Vserver: cluster-1
Key Server: ks1.local:1234
Timeout: 45
Username:
