ONTAP commands
network options multipath-routing show
Display multipath-routing
The network options multipath-routing show command displays the multipath routing configuration for the cluster.
cluster1::> network options multipath-routing show
                Is Multipath Routing Enabled: false
Looking for answers?
Try Doc, our Gen AI Assistant.
