storage automated-working-set-analyzer volume show
Displays the Automated Working Set Analyzer volume table
The automated-working-set-analyzer volume show command displays the volume statistics reported by the corresponding Automated Working-set Analyzer running instances.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node (privilege: advanced)
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}] - Flash Cache Node-wide Modeling (privilege: advanced)
This parameter indicates whether the AWA is modeling flash-cache.
[-vol-uuid <UUID>] - Uuid of the Volume (privilege: advanced)
This parameter indicates the volume uuid that this command is issued on.
[-aggregate <aggregate name>] - Aggregate (privilege: advanced)
This parameter indicates the aggregate name that the AWA instance runs on.
[-volume <volume name>] - Volume (privilege: advanced)
This parameter indicates the volume name that this command is issued on.
[-rank <integer>] - Cache Benefit Rank (privilege: advanced)
This parameter indicates the rank of this volume among all volumes that would be most benefited by the modeled cache technology based on the AWA prediction.
[-read-throughput {<integer>[Bps|KBps|MBps|GBps]}] - Read Throughput (privilege: advanced)
This parameter indicates the maximum read throughput over an interval that AWA has observed from the storage disks for this volume.
[-write-throughput {<integer>[Bps|KBps|MBps|GBps]}] - Write Throughput (privilege: advanced)
This parameter indicates the maximum write throughput over an interval that AWA has observed to the storage disks for this volume.
[-cacheable-read <percent>] - Cacheable Read (privilege: advanced)
This parameter indicates the maximum percent of cacheable read over an interval that AWA has observed for this volume. Cacheable reads are non-sequential reads, i.e., the percentage of data reads that could have been cached.
[-cacheable-write <percent>] - Cacheable Write (privilege: advanced)
This parameter indicates the maximum percent of cacheable write over an interval that AWA has observed. Cacheable writes are random overwrites, percentage of disk writes that could have been cached.
[-projected-cache-size {<integer>[KB|MB|GB|TB|PB]}] - Max Projected Cache Size (privilege: advanced)
This parameter indicates the projected Flash Pool cache usage by this volume.
[-projected-read-hit <percent>] - Projected Read Hit (privilege: advanced)
This parameter indicates the percentage of blocks that could be read from the Flash Pool cache instead of HDDs for this volume.
[-projected-write-hit <percent>] - Projected Write Hit (privilege: advanced)
This parameter indicates the percentage of block overwrites that could go to the Flash Pool cache instead of HDDs for this volume.
[-num-intervals-show <integer>] - Number of intervals to show (privilege: advanced)
This parameter indicates the number of intervals to the past this command is showing.
cluster1::> cluster-1::*> storage automated-working-set-analyzer volume show
Node          FC    Aggregate    Volume       Rank  Read Thrupt Write Thrupt
vsim1         false aggr0        vol0            1   230.47KBps   580.09KBps
