metrocluster configuration-settings interface show
Display the network logical interfaces provisioned for MetroCluster
The metrocluster configuration-settings interface show command displays the network logical interfaces that were provisioned for MetroCluster.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>] - DR Group ID
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>] - Cluster UUID
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
[-cluster <Cluster name>] - Cluster Name
If this parameter is specified, the command displays information for the matching cluster..
[-node-uuid <UUID>] - Node UUID
If this parameter is specified, the command displays information for the matching nodes uuid.
[-node <text>] - Node Name
If this parameter is specified, the command displays information for the matching nodes.
[-home-port {<netport>|<ifgrp>}] - Home Port
If this parameter is specified, all interfaces with home-port set to this value are displayed.
[-address <IP Address>] - Network Address
If this parameter is specified, the command displays information for the matching network address.
[-netmask <Contiguous IP Mask>] - Netmask
If this parameter is specified, all interfaces with netmask set to this value are displayed.
[-gateway <IP Address>] - Gateway
If this parameter is specified, all interfaces with gateway set to this value are displayed.
[-config-state <text>] - Configuration State
If this parameter is specified, all interfaces with this field set to the specified value are displayed.
[-config-error-info <text>] - Configuration Error Information
[-vlan-id <integer>] - Virtual LAN ID
If this parameter is specified, all interfaces with vlan-id set to this value are displayed.
The following example illustrates display of logical interfaces configured in a four-node MetroCluster setup:
clusA::> metrocluster configuration-settings interface show
DR        Config
Group Cluster Node    Network Address Netmask         Gateway         State
1     clusA A1
                 Home Port: e0f
                      10.140.113.214  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.215  255.255.192.0   -               completed
                       A2
                 Home Port: e0f
                      10.140.113.216  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.217  255.255.192.0   -               completed
      clusB B2
                 Home Port: e0f
                      10.140.113.249  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.25   255.255.192.0   -               completed
                       B1
                 Home Port: e0f
                      10.140.113.218  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.248  255.255.192.0   -               completed
8 entries were displayed.
