vserver services access-check authentication login-cifs
- PDF of this doc site
Creating your file...
Authenticate a CIFS user
The vserver services access-check authentication login-cifs
command authenticates a Windows user through the specified node using the specified Vserver's configuration. Upon success, it displays the user's Windows and UNIX credentials.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
The name of the node on which the command is executed.
-vserver <vserver>
- Vserver (privilege: advanced)-
The name of a Vserver with a configured CIFS server.
-user <text>
- Windows Name (privilege: advanced)-
The name of a user that is a member of the Windows or a trusted domain that the CIFS server in the specified Vserver belongs to.
[-clientIp <IP Address>]
- Client IP Address (privilege: advanced)-
The IP address of the client as specified by the user
This example authenticates the Windows user "administrator" through node "node2" using the configuration of "vs1." Upon success, it displays the Windows and UNIX credentials for user "administrator."
cluster1::vserver services access-check*> authentication login-cifs -vserver vs1 -user administrator -node node2 Enter the password: Windows User: administrator Domain: EXAMPLE Privs: a7 Primary Grp: S-1-5-21-1407423728-2963865486-1834115207-513 Domain: S-1-5-21-1407423728-2963865486-1834115207 Rids: 500, 520, 513, 22226, 26625, 1842, 512, 519, 518, 8323, 1645, 1648, 1644, 1647 Domain: S-1-1 Rids: 0 Domain: S-1-5 Rids: 11, 2 Unix ID: 0, GID: 0 Flags: 1 Domain ID: 0 Other GIDs: Authentication Succeeded.
