ONTAP commands
system services firewall policy modify
Modify a firewall policy entry for a network service
The system services firewall modify command enables you to modify the list of IP addresses and netmasks associated with a firewall policy.
-vserver <vserver> - Vserver Name
Use this parameter to specify the Vserver of the policy to modify.
-policy <textpolicy_name> - Policy
Use this parameter to specify the name of the policy to modify.
-service <service> - Service
Use this parameter to specify the policy's network service to modify.
[-allow-list <IP Address/Mask>,…​] - Allowed IPs
Use this parameter to specify one or more IP addresses with corresponding netmasks that are allowed by this firewall policy. The correct format for this parameter is address/netmask, similar to "192.0.2.128/25". Multiple address/netmask pairs should be separated with commas. Use the value 0.0.0.0/0 for "any".
The following example modifies the firewall policy named data that uses the NDMP protocol to enable access from all addresses on the 192.0.2.128 subnet:
cluster1::> system services firewall policy modify -policy data -service ndmp -allow-list 192.0.2.128/25
