      system services firewall policy clone
Clone an existing firewall policy
The system services firewall policy clone command creates a new firewall policy that is an exact copy of an existing policy, but has a new name.
-vserver <text>- Vserver owning the Policy-
Use this parameter to specify the name of the Vserver owning the existing policy to copy.
 -policy <text>- Firewall Policy to be Cloned-
Use this parameter to specify the name of the existing policy to copy.
 [-destination-vserver <text>]- Vserver owning the New Firewall Policy-
Use this parameter to specify the name of the Vserver that will own the new policy to create.
 -destination-policy <text>- Name of New Firewall Policy-
Use this parameter to specify the name of the new policy to create.
This example creates a new firewall policy named "data2" on Vserver "vs0" from an existing firewall policy named "data" on Vserver "vs1".
cluster1::> system services firewall policy clone -vserver vs0 -policy data -destination-vserver vs1 -destination-policy data2
