The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system services firewall policy clone
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Clone an existing firewall policy
This command is deprecated and may be removed in a future ONTAP release. Use network interface service-policy clone instead. |
The system services firewall policy clone
command creates a new firewall policy that is an exact copy of an existing policy, but has a new name.
-vserver <text>
- Vserver owning the Policy-
Use this parameter to specify the name of the Vserver owning the existing policy to copy.
-policy <text>
- Firewall Policy to be Cloned-
Use this parameter to specify the name of the existing policy to copy.
[-destination-vserver <text>]
- Vserver owning the New Firewall Policy-
Use this parameter to specify the name of the Vserver that will own the new policy to create.
-destination-policy <text>
- Name of New Firewall Policy-
Use this parameter to specify the name of the new policy to create.
This example creates a new firewall policy named "data2" on Vserver "vs0" from an existing firewall policy named "data" on Vserver "vs1".
cluster1::> system services firewall policy clone -vserver vs0 -policy data -destination-vserver vs1 -destination-policy data2
