ONTAP commands
snaplock log show
Display audit log configuration.
The snaplock log show command displays the following information about the SnapLock log infrastructure:
  • Vserver name
  • Volume name
  • Maximum log size
  • Default retention period
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter is specified, the command displays the log information for Vserveers that match the specified value.
[-volume <volume name>] - Log Volume Name
If this parameter is specified, the command displays the log configuration for volumes that match the specified value.
[-max-log-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum Size of Log File
If this parameter is specified, the command displays the log configuration with a matching -max-log-size value.
[-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Default Log Record Retention Period
If this parameter is specified, the command displays the log configuration with a matching -default-retention-period value.
cluster1::> snaplock log show -vserver vs1
Vserver Name                        : vs1
      Log Volume Name                     : 15MB
      Maximum Size of Log File            : 15MB
      Default Log Record Retention Period : 6 months
        Vserver           Volume              Maximum Size        Retention Period
        vs1               vol1                15MB                6 months
