job initstate show
PDF of this doc site
Creating your file...
Display init state for job managers
The job initstate show
command displays information about the initialization states of job-manager processes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the nodes that match this parameter value.
[-process <process_name>]
- Process Name (privilege: advanced)-
[-initialized {true|false}]
- Initialized? (privilege: advanced)-
Selects the nodes that match this parameter value (
true
means initialized;false
means not initialized). [-cache-root <text>]
- Cache Root (privilege: advanced)-
[-siteid <UUID>]
- Site ID (privilege: advanced)-
[-hp-threads <integer>]
- High Priority Threads (privilege: advanced)-
Selects the nodes that have the number of high-priority threads you specify.
[-mp-threads <integer>]
- Medium Priority Threads (privilege: advanced)-
Selects the nodes that have the number of medium-priority threads you specify.
[-lp-threads <integer>]
- Low Priority Threads (privilege: advanced)-
Selects the nodes that have the number of low-priority threads you specify.
[-tx-interval <integer>]
- Transaction Interval (privilege: advanced)-
Selects the nodes that have the number of seconds you specify as their transaction interval.
[-initmsg <text>]
- Initialization Message (privilege: advanced)-
[-thread-initmsg <text>]
- Thread Initialization Message (privilege: advanced)-
Selects the nodes that match this parameter value. The thread initialization message contains information about thread status. If there is no information to communicate, this message is empty.
[-recovery-enabled {true|false}]
- Job Failover Enabled? (privilege: advanced)-
true
means enabled,false
means not enabled). [-ex-threads <integer>]
- Exclusive Priority Threads (privilege: advanced)-
The following example shows how to display general job-manager initialization-state information for a cluster.
cluster1::*> job initstate show HP MP LP EX Node Process Init? Thr Thr Thr Thr TX Int Failover? ----------------- ----------- ----- ---- ---- ---- ---- ------ --------- node1 mgwd true 2 3 5 8 300 true node2 mgwd true 2 3 5 8 300 true 2 entries were displayed.
The following example shows how to display detailed job-manager initialization-state information for a node named node0
cluster1::*> job initstate show -instance -node node0 Node: node0 Process Name: mgwd Initialized?: true Cache Root: /mroot/jm_cache Site ID: 824e8f7d-f49-1d9-84af-00423b7352 High Priority Threads: 2 Medium Priority Threads: 3 Low Priority Threads: 5 Transaction Interval: 300 Initialization Message: Initialized Are Threads Running?: - Job Failover Enabled?: true Exclusive Priority Threads: 8
