vserver config-replication pause
Temporarily pause Vserver configuration replication
Vserver domain locking functionality locks the Vserver while Vserver DM is recording a configuration baseline. This command aborts the ongoing baseline generation activity, unlocks the Vserver and temporarily pauses configuration replication for the Vserver. Command confirmations have to be enabled to execute this command. The time at which replication resumes is displayed after successful completion of the command. Configuration changes made after executing this command are not replicated to the partner cluster. If a disaster occurs during this time, the configuration changes made are lost. Replication can be manually resumed by executing the vserver config-replication resume command.
-vserver <vserver name>
- Vserver name-
== Examples
cluster::> vserver config-replication pause -vserver vs1 Vserver configuration replication will be paused, then automatically resumed after five minutes. Manually resume configuration replication by running the "vserver config-replication resume -vserver vs1" command. Do you want to continue ? {y|n}: y Vserver configuration replication is paused and will be resumed at: 5/24/2014 06:11:23
