      security saml-sp repair
Repair a failed SAML SP configuation
The security saml-sp repair command attempts to repair a failed SAML SP configuration on a given node. The status of the individual nodes can be viewed using the security saml-sp status show command.
This restarts the web server. Any active HTTP/S requests to the web server will be disrupted. |
-node {<nodename>|local}- Node (privilege: advanced)-
This identifies a single node that matches the input. The repair job will run on this node.
 [-foreground {true|false}]- Foreground Process (privilege: advanced)-
When this parameter is set to
falsethe command runs in the background as a job. The default istrue, which causes the command to return after the operation completes.
The following example repairs a failed SAML SP configuration:
cluster1:> security saml-sp repair -node node-2
Warning: This restarts the web server. Any active HTTP/S requests to the web
Do you want to continue? {y|n}: y
      [Job 1321] Job succeeded.
cluster1:>
