event mailhistory show
(DEPRECATED)-Display a list of e-mail history records
|  | This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event notification history" command set. |
The event mailhistory show command displays a list of the event notifications that have been e-mailed. The command output depends on the parameters you specify with the command. By default, the command displays basic information about all notification e-mails that were sent.
To display detailed information about a specific mail-history record, run the command with the -seqnum parameter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Selects the mail-history records that match this parameter value.
- [-seqnum <Sequence Number>]- Sequence Number
- [-message-name <Message Name>]- Message Name
- [-address <mail address>,…]- Mail Address
- [-time <MM/DD/YYYY HH:MM:SS>]- Transmission Time
- [-message <text>]- Alert Message
Selects the mail-history records that match this parameter value (text pattern).
- [-previous-time <MM/DD/YYYY HH:MM:SS>]- Previous Transmission Time
- [-num-drops-since-previous <integer>]- Number of Drops Since Previous Transmission
Selects the mail-history records that match this parameter value (number of event drops since last transmission).
The following example displays detailed information about the mail-history record with the sequence number 20520:
cluster1::> event mailhistory show -seqnum 20520
    Sequence Number:  20520
       Message Name:  wafl.vol.full
            Address:  admin@example.com
               Time:  10/1/2008 14:06:24
               Node:  node3
      Previous Time:  5/31/2007 00:33:22
 # Drops Since Prev:  0
       Mail Message:  wafl.vol.full: file system on volume
                      vol0@vserver:28558fe3-2462-11da-85ab
                      -000423bacd20 is full
 PDFs
PDFs
