ONTAP commands
system snmp init
Enables or disables SNMP traps
Initializes or disables sending of traps by the SNMP daemon from the cluster.
[-init <integer>] - Initialize Traps
Use the value of 1 to initialize SNMP daemon to send traps or use a value of 0 to stop sending traps from the cluster. If no value is specified, this command displays the current setting of init. Traps are enabled by default.
The following command initializes SNMP daemon to send traps. +
cluster1::> system snmp init -init 1
uster1::> system snmp show
contact:
        private
        NB
authtrap:
        1
init:
        1
traphosts:
community:
