metrocluster check config-replication show-aggregate-eligibility
The metrocluster check config-replication show-aggregate-eligibility command displays the MetroCluster configuration replication aggregate eligibility.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
This is the aggregate name. If this parameter is specified, only rows with this aggregate will be displayed.
[-hosted-configuration-replication-volumes <volume name>,…​] - Currently Hosted Configuration Replication Volumes
This is the list of the configuration replication volumes hosted on this aggregate. If this parameter is specified, only rows with these configuration replication volumes will be displayed.
[-is-eligible-to-host-additional-volumes {true|false}] - Eligibility to Host Another Configuration Replication Volume
This is the eligibility of the aggregate to host additional configuration replication volumes. If this parameter is specified, only rows with this eligibility will be displayed.
[-comment <text>] - Comment for Eligibility Status
This is a comment regarding the eligibility of the aggregate to host configuration replication volumes. If this parameter is specified, only rows with this comment will be displayed.
The following example shows the execution of the command in a MetroCluster configuration with thirteen aggregates in the cluster:
clusA::metrocluster check config-replication> show-aggregate-eligibility
                                                        Eligible to
Aggregate    Hosted Config Replication Vols             Host Addl Vols Comments
a0           -                                          false          Root Aggregate
a1           MDV_CRS_1bc7134a5ddf11e3b63f123478563412_A true           -
a2           MDV_CRS_1bc7134a5ddf11e3b63f123478563412_B true           -
a3           -                                          false          Unable to determine available space of aggregate
a4           -                                          false          Non-Local Aggregate
a5           -                                          false          Non-Home Aggregate
a6           -                                          false          Unable to determine mirror configuration
a7           -                                          false          Mirror configuration does not match requirement
a8           -                                          false          Disallowed Aggregate
a9           -                                          false          Insufficient Space - 10GB required
a10          -                                          false          Aggregate Offline
a11          -                                          false          Inconsistent Aggregate
a12          -                                          false          Aggregate Full
13 entries were displayed.
