metrocluster check config-replication show-aggregate-eligibility
The metrocluster check config-replication show-aggregate-eligibility command displays the MetroCluster configuration replication aggregate eligibility.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]- Aggregate-
This is the aggregate name. If this parameter is specified, only rows with this aggregate will be displayed.
[-hosted-configuration-replication-volumes <volume name>,…]- Currently Hosted Configuration Replication Volumes-
This is the list of the configuration replication volumes hosted on this aggregate. If this parameter is specified, only rows with these configuration replication volumes will be displayed.
[-is-eligible-to-host-additional-volumes {true|false}]- Eligibility to Host Another Configuration Replication Volume-
This is the eligibility of the aggregate to host additional configuration replication volumes. If this parameter is specified, only rows with this eligibility will be displayed.
[-comment <text>]- Comment for Eligibility Status-
This is a comment regarding the eligibility of the aggregate to host configuration replication volumes. If this parameter is specified, only rows with this comment will be displayed.
The following example shows the execution of the command in a MetroCluster configuration with thirteen aggregates in the cluster:
clusA::metrocluster check config-replication> show-aggregate-eligibility
Eligible to
Aggregate Hosted Config Replication Vols Host Addl Vols Comments
a0 - false Root Aggregate
a1 MDV_CRS_1bc7134a5ddf11e3b63f123478563412_A true -
a2 MDV_CRS_1bc7134a5ddf11e3b63f123478563412_B true -
a3 - false Unable to determine available space of aggregate
a4 - false Non-Local Aggregate
a5 - false Non-Home Aggregate
a6 - false Unable to determine mirror configuration
a7 - false Mirror configuration does not match requirement
a8 - false Disallowed Aggregate
a9 - false Insufficient Space - 10GB required
a10 - false Aggregate Offline
a11 - false Inconsistent Aggregate
a12 - false Aggregate Full
13 entries were displayed.
