system node image package show
Display software package information
The package show command displays details of the software packages residing on the storage controller.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects which node's packages are displayed. The local node is the default if this parameter is omitted.
[-package <text>]
- Package File Name (privilege: advanced)-
This parameter specifies which package's information will be displayed.
cluster1::> system image package show Package Node Repository Package File Name ---- ---------- ----------------- node-01 mroot image.tgz 1 entries were displayed.
