      vserver peer repair-peer-name
Repair the peer vserver name that was not updated during the last rename operation
Updates the peer Vserver name in remote peer clusters for the specified Vserver in the local cluster.
-vserver <vserver>- vserver (privilege: advanced)-
Name of the Vserver in the local cluster. This name will be repaired on remote peer clusters.
The following example updates the peer-Vserver name across the peered clusters:
cluster1::*> vserver peer repair-peer-name -vserver vs1.example.com Info: Command completed successfully
